585,749 active members*
3,819 visitors online*
    Feb 2008
    92
    CNC conversion to Mach Control
    We have a older CNC Bed mill. It is some sort of company retrofit. It is called Racer Tech.
    Anyway we have found that the software on the machine is limited. It is dos format(which is ok) and it wont move 3 axis at once. It is also very basic from a control standpoint. Hard to edit programs on the control and such.
    My questions is has anybody changed a CNC machine to Mach software? How hard was it? Any problems? Advice?
    Oct 2006
    323
    That CAT has been skinned
    Retrofitting a CNC to MACH3 control has been done many times.
    To better assess your path forward, you need to inventory your current system. Get and record the various info.
    Axis motor info
    stepper or servo
    rated voltage amps
    torque (holding, peak, continuos)
    frame/mount size (if replacing)
    shaft size & lenght, dual for encoder, dimensions of encoder shaft (if replacing)
    Amp/driver info
    control signal
    + 10 Vdc
    dir +10 Vdc
    dir & step
    Rated voltage and amps
    Armed with this information you can start searching and reading threads and start choosing a path.
    If considering MACH3 also consider EMC2.
    If you are looking for more turnkey or packaged kits, maybe look at Centroid, Ajax, or Camsoft.
    Your journey begins.
    Feb 2008
    92
    Thanks for the response.
    What replaces the drivers for the servos?
    If I understand this correctly. Mach software is the control portion but what is needed to give feedback to the servos. Basically what I am trying to do is go from a 2.5axis machine to a full 3 axis machine. The software on the machine now will not make a x y and z move at the same time(ex N45 G01 X.0 Y5.3 Z 3.5)
    Any insight?? Very much a newbie on what I need.
    Oct 2006
    323
    On the road...
    Correct, Mach3 and your PC constitute your controller. It is capabale of 3 axis interpolated moves, and I believe up to 6 axis (personally I haven't even delved much into the 4th).
    You may be able to keep your drivers and servos depending on the type and how you want to 'interface' with Mach/PC. The most direct/straight forward interface route is parallel port to optional BOB (breakout board) to step/dir capable servo drivers/amplifiers (e.g. Gecko 320) with encoder feedback to the drive.
    Your current servos and amps are likely not step/dir and encoder feedback, but more probable +10 analog with tachometer and encoder or resolvers for feedback to the amp/controller. If you wish to retain these, you will need to look into alternative interface hardware, e.g. Galil, CNCBrain, or EMC2(PC control SW) and Mesa 5i20/7i33, etc.
    Your z is currently servo driven? Just not interpolated moves?
  1. Mach to EMC conversion guide?
    By randyf1965 in forum LinuxCNC (formerly EMC2)
    Last Post: 03-05-2008, 06:06 PM
  2. BP Series 1 Anilam > Mach conversion...?
    By arpieb in forum Bridgeport / Hardinge Mills
    Last Post: 01-05-2008, 01:17 AM
  3. Boss 8 to Mach Conversion Help
    By TurboStew in forum Bridgeport / Hardinge Mills
    Last Post: 10-27-2006, 02:44 AM
  4. Practical cnc to Mach conversion
    By cut more in forum Machines running Mach Software
    Last Post: 05-25-2006, 06:22 PM
  5. Beginning Crusader to Mach 2 Conversion Please Help
    By MMT in forum Bridgeport / Hardinge Mills
    Last Post: 10-31-2005, 06:13 AM
