585,589 active members*
3,543 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Plasma Table size recommendatation? 4x4, 5x5, 5x9
    May 2006
    47
    I am getting ready to start a cnc plasma build. I am looking for recommendations for what a good size table would be to build. I am a hobbyist and for the most part I figure I will be cutting brackets, decorations, etc. I can't see a single part needing to be bigger than 4'x4'
    I figure a 4x4 would be a little small because you couldn't really cut a 4'x4' sheet on it.
    A 5'x9' or 5'x10' would be good because you could drop an entire 4'x8' sheet on it and cut away. The down side of this would be the space required as well as the shear weight of the 4'x8' sheet of metal.
    I think I am leaning towards a 5'x5' table that will let me cut a 4'x4' sheet of steel and still be able to keep a fair amount of garage space. I could always cut off of a 4'x8' sheet by hanging part of the sheet off the table on a stand.
    Any experience and/or recommendations would be appreciated.
    Brian
    Jan 2008
    2247
    5 foot wide (x 10) is usually cheaper by the square foot than 4 foot wide. And......you cannot usually buy 4 x 4 sheets without some sort of a cutting charge. I have a 4 x 4 (PlasmaCam) but have configured a support roller system that will accomodate 4 x 8. I wish I had a 5' wide system so I could buy steel in 5 x 10 pieces.
    The PlasmaCam software allows you to easily cut parts bigger than 4 x 4 by cutting everything in the 4 x 4 perimeter...then allowing you to index (move) the plate to cut up to 4 x 12.
    Of course......the other issue is material handling.....how do you move large plates on and off the table.....another subject entirely for the small, one person shop!
    Jim Colt
    Feb 2007
    514
    Mine is 50" (of cutting area) on the X axis and 36" on the Y axis. As Jim said you can index the sheet. I can load a 4 x 8 sheet as it can stick out on either end of the table as needed. I usually get my sheets cut to 4 x 4 for a nominal charge and I can handle up to 11 gauge by myself. It also makes it easy to store the 4 x 4 sheets next to the plasma table on a rack.
    John
    Feb 2006
    1260
    If you are wanting to load easily & 4 X 4 is your desired size sheet 4'6" is wide enough but to have gantry run off room on the length of the table is quite desirable. The length of the cutting surface would be ok at slightly over 4' but I'd want the gantry moved completely from off the cutting surface.. I'd also want a dropped front rail table to make loading & unloading from either the end or side easy.
    If it works.....Don't fix it!
    Feb 2008
    121
    I purchased a table 4x4 with a single sided gantry, I can easily load a 4x8 sheet from the side and it can hang over each end.. It cuts a full 4 feet in each direction. So if i want i can cut my 4x8 sheets in half. If I was to purchase another table I would probably go with a 4x8 set up.... I purchase my steel by the pound so it doesn't matter what size the sheet is..
  1. Table Size for a TM3?
    By schoobie in forum Torchmate
    Last Post: 03-22-2008, 06:40 PM
  2. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum LinuxCNC (formerly EMC2)
    Last Post: 10-05-2007, 10:52 AM
  3. Drawing Size and Cut Size Differ - Plasma
    By ADucci in forum Mach Plasma / Laser
    Last Post: 10-04-2007, 02:49 PM
  4. table size
    By Jimmyh in forum Mach Software (ArtSoft software)
    Last Post: 08-30-2007, 04:33 PM
  5. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
