Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Toby,
I tried Alibre and maybe didnt give it enough input on my part. The express is still sitting there waiting for me to revisit it. Since your an Alibre user, could you show how to have the control over the areas of surface Don is reffering to using Dons curves? This would be great knowledge for me as well.
Burr
While Alibre is strong in the parametric and solids area it is weaker in the surfacing area. Freeformed surfaces can not be done as there are no current tools.
However you can create lofts using guide lines in Alibre. It will just need to be a solid instead of an independant surface.
Toby D.
Schwarzwald
from what I have read Rhino seems to be a very good solid surfacing tool...But I think that is thier strong point...But I do like the option Toby pointed out... as there have been more than one time that I did not what to cut the raduis/chamfer in a 3D model just because of time...I could go back and do it in another operation. But to just turn it off would be great...
Tim adleast you had a warm week in Detroit
BTW: Tim you might like to know that Free Design is developing a Plug-In Module for Alibre Design while Rhino already has one that you know about already.
http://www.freedesign3d.com/index.cfm
Toby D.
Schwarzwald
You could then extract the surface in BobCad!
The abilty to set guides would be what we're after. Thats what I believe is missing here in BobCads surface creation tools (Though I could be wrong. I dont quite have a total grasp of using the various skinning functions in BobCad) The lofting with Alibre may pose the same constraint as the cross section method does in BobCad. It is possible to acheive his result with BobCad but impractical to design the cross sections to specs, "when trying to reverse engineer the product".
In Alibre, Possibly lofting the top curve as a whole with the Middle Curve, using the re-curve as a control curve may work. Although loft doesnt usually work with that "Crossing curves" type operation.
Toby D.
Schwarzwald
Toby D.
Schwarzwald
"Alibre's Loft"
Yeah that wont acheive what Don is after.
Even the other freedesign software wont do what he's requesting. If it was just a matter of adjusting the curves, he could do that in BobCad with the little part that dips at the last minute.
He's requiring higher end surfacing tools because of the "reverse engineering" approach. The requirement to hit a pre-existing skin shape at pre-existing points.
The ability to control the "sweep" of the skin is needed here.
Toby D.
Schwarzwald
Burrman you and Don may want to try Rhino...curved surfaces are their strong siut...You can do them from splines and points
Hi Toby,
Don is working out of V22 and thats the app I've been using to help him. You can refer to the last file we were discussing here:
http://www.cnczone.com/forums/showpo...&postcount=126
And if you read the next 2 or 3 you will see what he is objecting to in the "Flow of the skin" through his lowest curve.
Also Don,
Was it you mentioning that the Backup wasnt working in V23??? I couldnt find the thread to respond to but thought I remembered it was you.
Burr
Oh, to have those parametric tools built into BobCad....that might make my heart go all-a-flutter.
Toby, those design tools sound awesome. And only $1600 for the package. That's not too shabby for that kind of power. Not that I have $1600 to spend, but it's a good deal.
What Burr said about being able to control the sweep is exactly what I was concerned about. I've been trying to adjust the curves to make them go more smoothly. Of course now the scroll part is something that really concerns me, because it's spiraling and concave at the same time.
Man, the stuff I miss when I leave my computer off for one evening!
