585,754 active members*
3,801 visitors online*
    Mar 2005
    11
    Memory Batteries
    I am purchasing gently used 1990 model BMC20 currently under power and will not be able to get power to it for 1-2 months after I take delivery. I have read other post were people have problems with the batteries dying and the machine not functioning after this happens. Should I be concerned for not supplying power to the machine for this amount of time? Is there any thing I can do to keep the batteries functioning during this time period?
    Oct 2008
    18
    Hi. I have 1990 Hurco BMC30 with CNC Ultimax 3. Machine was without power about 1 year and it was any problem to start it. So, good luck.
    Oct 2008
    42
    If your machine is an Ultimax 2 then the batteries could be an issue, If it is an Ultimax 3 then the software is on a hard disk so no worries, although there is a cmos battery on the CPU board. www.amtsinc.com
    Buddy
  1. Fanuc 10M Parameters...no batteries
    By spank in forum Fanuc
    Last Post: 03-29-2011, 08:56 AM
  2. Mazak M2 batteries.
    By gridley51 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-01-2008, 09:01 PM
  3. Memory Batteries AM1
    By greenchair in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-31-2008, 07:42 PM
  4. DT-Center Batteries ??
    By scott1980 in forum Uncategorised MetalWorking Machines
    Last Post: 05-02-2007, 03:21 PM
  5. R2E3 batteries?
    By sharp-shooter in forum Bridgeport / Hardinge Mills
    Last Post: 11-20-2006, 05:02 AM
