521,887 active members*
1,621 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > half-working G210 :(
Results 1 to 6 of 6
    Registered
    Sep 2007
    Hello. Yesterday i connected my step motor to GeckoDrive G210 driver. G210 connected to PC through LPT port, common +5v coming from PC PSU.
    But motor rotates well only in one direction. In other direction motor rotation is very unstable and it stalls.
    If i connect G201 instead of G210 - everything works well. Is my G210 broken? It seems like G210 has wrong understanding of DIR signal
    Gold Member
    Dec 2004
    1865
    Make sure that your header option on the g210 is set for the proper common, which I believe is common 5v to match the g201.
    http://www.geckodrive.com/upload/G210-REV-11-MANUAL.pdf
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    rqet,
    Your problem is the parallel port outputs 3.3V signals while the G210 requires 5V signals. You will have to get a breakout board that buffers the signals to 5V levels.
    Mariss
    Registered
    Sep 2007
    Thats right, thanks. I connected 500 ohm resistor between DIR and +5v terminals and now it works ok!
    It only seems to work. You cannot pull 3.3V outputs up to 5V. Measure the DC voltage with a multimeter; you will get 3.6 to 3.9V. The drive will be susceptible to missed steps. You really need to get a breakout board.
    Mariss
    Member
    May 2020
    11
    Re: half-working G210 :(
    I was surfing net and fortunately came across this site and found very interesting stuff here. Its really fun to read. I enjoyed a lot. Thanks for sharing this wonderful information. 먹튀 검증
  1. g210 what motor
    By bubbax1 in forum Gecko Drives
    Last Post: 06-30-2008, 04:28 PM
  2. G210 usage
    Last Post: 05-18-2008, 10:56 PM
  3. G210 jumper settings
    By moxy in forum Gecko Drives
    Last Post: 12-21-2007, 10:00 AM
  4. Motor Speed of G210/G210 can be reach?
    By phx2002 in forum Gecko Drives
    Last Post: 01-21-2007, 01:53 AM
  5. G210 can do Bipolar wiring ?
    By Calico in forum Gecko Drives
    Last Post: 04-14-2005, 01:19 PM
