Hi Folks,
I'm hoping someone can double check my math here concerning a power supply. So far I am the epitome of bad buys and costly mistakes in the CNC world. I should write a "Don't follow my lead" book.
Here's what I have and what I have come up with. I have two Nema 34's at 2.0 volts, 6 amps each running on my x and y axis. 1/2" 1-8 4 start turn direct drive. I have a Nema 23 at 2.8 amps and 3.64 volts on my z axis with 1/2" 1-10 single start. I don't want my power supply to the drivers to go much over 40 volts although I can go 50 tops.
Averaging all I come up with 2.54 stepper volts average, times 20 equalling 51 volts. I want the driver supply roughly at 40 volts so divided by 1.4 I get 28.6 VAC. Averaging stepper amps I have 9.91 amps, times 20 to get 198.2VA. My calculations show I need a 28,000 capacitor.
I have rounded up a 250VA 30V+30V Toroidal Transformer, two 26k uf 75 volt capacitors and a 15amp 240V rectifier.
Am I going up in smoke again or am I on the right track? I do have a switching power supply I can use on the z axis if needed. I prefer to have things all linear however.
Thanks ahead of time!
Slim
