585,727 active members*
4,065 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > G54 problems, machine goes to "new" cord. but won't machine features
    Feb 2005
    24
    BobCAD20.4
    1st set of hole no problem, machine moves to "new" cord. 1 inch over, however, it will not drill, it goes over 1 inch and moves right back to the master cord 1,1
    thanks, I've tried it multiple ways and have even found "examples" off the net with no luck if I try and run them thru the Simulator
    N5 G90 G80 G20
    N10 M06 T6
    N15 M03 S1300
    N20 G55 G00 X1.0 Y1.0
    N25 Z0.5
    N30 G82 Z-.25 R0.125 F5
    N35 Y2
    N40 X2
    N45 Y1
    N50 X1.5 Y1.5
    N60 G80 G00 Z1
    N65 G56 G00 X1.0 Y1.0
    N70 Z0.5
    N75 G82 Z-.25 R0.125 F5
    N80 Y2
    N85 X2
    N90 Y1
    N95 X1.5 Y1.5
    N100 G80 G00 Z1
    N102 G54
    N105 X0 Y0
    N110 M05
    May 2007
    781
    Some controls will read a word like Y2 as 0.0002 instead of the 2.0000 you most likly intend, you may want to put a DP after the number, Y2. and see what happens.
    Edit:
    Also if you are not using a dwell, the P word in a G82 you may want to switch to a G81 and see if that is messing up the control.
  1. Index to "Epoxy-Granite machine bases" thread
    By walter in forum Epoxy Granite
    Last Post: 12-02-2011, 05:45 AM
  2. Tube Bending Machine Capable of 2"x4" Rectangular Tubing
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 06-27-2010, 04:47 PM
  3. Post adds "A0." code and machine stops
    By lookingforhelp1 in forum Fanuc
    Last Post: 08-29-2008, 06:58 PM
  4. Post adds "A0." code and machine stops
    By lookingforhelp1 in forum Post Processors for MC
    Last Post: 08-29-2008, 06:14 AM
  5. Questions on building small (18" x 24" x 3") machine
    By bikedude880 in forum DIY CNC Router Table Machines
    Last Post: 08-01-2006, 03:04 AM
