585,589 active members*
2,932 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > feed rate override not working or i am dumb and its right there
    Jul 2005
    969
    do you have to enable fro not rapid but straight fro in mach3 the f10 and f11 button only change the dro but not the actual speed i did a quick search in the forum but all i found where people asking about rapid fro.
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
    What version are you using? It works in 2.63 and 3.42.020, although it seems to work a little quicker in 2.63. Do you have the box checked to lock them together in General config?
    Jul 2005
    969
    ok so if its check then fro wont go over 100% because rapid fro is allready at 100% is that it
    3.42.020
    editk thats kinda weird i have uncheck the lock between the rfro and the fro now it work but in order for it to work i have to do a feed hold and cycle start again
    edit2: ok unchecking the feed queu something solved the problem finally i am close to getting a machine that operates properly
  1. Lock out feed rate override
    By Daves 41 in forum Haas Mills
    Last Post: 04-21-2008, 11:14 PM
  2. Feed rate Ovverride also Increases rapid rate.
    By Korellibopper in forum Machines running Mach Software
    Last Post: 01-31-2008, 12:37 AM
  3. feed override keys
    By elpete0068 in forum Mach Wizards, Macros, & Addons
    Last Post: 01-16-2008, 08:44 AM
  4. Mach 3 & Feed Rate Override
    By aus-newb in forum Mach Lathe
    Last Post: 11-22-2005, 01:56 AM
  5. Feed Override
    By SCOJEN in forum DIY CNC Router Table Machines
    Last Post: 01-24-2005, 07:56 PM
