585,781 active members*
4,382 visitors online*
    Oct 2004
    590
    2x5 pin headers-why?
    I've noticed that in the unipolar control board and the 3 & 4 axis BOB you're using 2x5 header pins for connections. Since only 3 lines are actually being used why a 2x5 header? Why not just 1x3? Also why did you bring out pins 1 and 9 to a solder pad? Is there some future use in mind regarding these choices?
    Thanks!
    Chris
    Jun 2003
    3312
    Several reasons.
    1. A ground inerspersed with a signal is less prone to noise and adjacent signal coupling.
    2.10 pin IDC connectors and cable are more easy to come by.
    3. If you don't want to use IDC cable and headers you only wire discretely what you want.
    4. You have the flexability to share one 5VDC regulator.
    5. 5VDC might be needed to support opto isolation.
    Regarding pins 1 and 9. Two of the boards, the 3977 and L297-8 use pin 1 for enable. The pad gives the flexability to wire as you see fit. Pin 9 can be arranged to give or get 5vdc to those boards also as well as the discrete unipolar.
    Phil
    Oct 2004
    590
    Quote Originally Posted by pminmo
    Several reasons.
    Phil
    Would it work equally well to use shielded cable with a dedicated ground wire as well as a grounded shield drain wire?
    Thanks again!
    Chris
    Jun 2003
    3312
    Quote Originally Posted by OCNC
    Thanks again!
    Chris
    Yes, probably even a little better, simply use the adjacent gnd pin. All the even pins are wired to ground.
    Phil
  1. Staggering motors
    By viktorcnc in forum Stepper Motors / Drives
    Last Post: 10-25-2015, 08:11 PM
  2. Sourcing Hardware (1/8 Pin with threads)
    By Swami in forum MetalWork Discussion
    Last Post: 03-26-2005, 05:35 PM
  3. Troubleshooting the Simple BreakOutBoard and L297 driver
    By pigifly in forum Open Source Controller Boards
    Last Post: 11-10-2004, 09:13 PM
  4. DB25I/O and software
    By pminmo in forum CNC Machine Related Electronics
    Last Post: 08-13-2004, 02:27 PM
  5. Pc Rs232 > Fanic 10te-f
    By abselect in forum CNC Machine Related Electronics
    Last Post: 07-06-2004, 03:23 PM
