585,974 active members*
4,338 visitors online*
Results 1 to 6 of 6
    Oct 2004
    10
    ER16 Collets **INCH**
    Does anyone have a source for ER16 collets that are ground for INCH
    fractional tooling shanks?
    All the dual metric/inch marked collets are metric. Yes they will close down ok
    on inch shanks, but it's very agrivating to do so. Just try the 1/4"
    shank in a 6-7mm collet. It has to be closed almost all the way to grip.
    Besides accuracy suffering, I hate the hazard of dropping tooling out when
    the tool suddenly pops out with the collet being pulled loose.
    A friend has the fractional ground jobs and a shank will stay in. Nice.
    These used to be available from Enco.
    Thanks for any help.
    RichD, Atlanta
    May 2006
    1469
    Search this ebay number, 330271729372
    Jun 2006
    2512
    Google works pretty good to, for example:
    http://www.maritool.com/Collets-ER-S..._61/index.html
    Wakey wakey.
    Phil
    Quote Originally Posted by cnciam View Post
    RichD, Atlanta
    Jan 2007
    634
    Combo inch/metric collets are pretty much junk.
    The Taig stock ER-16 collet sets are in inch, fit very well, and are actually very decent for the price.
    There are certainly more accurate ones out there for several hundred bucks a set, but at that point you have to look at the spindle they are going in though. The Taigs stock spindle is freakin' amazing - its almost inconceivably accurate for a sixty dollar unit, but its still not a two thousand dollar NSK. The really pricey high-end collets probably won't make a noticable difference in the stock unit, so I'd recommend just sticking with the fifty dollar Taig set.
    May 2007
    781
    Royal makes native inch size ERs, like Stepper says a bit pricey and over kill for a small hobby mill but if you only need one or two sizes its not that bad and they should last forever.
    http://www.royalprod.com/content/fil...Pgs_14_171.pdf
    Jun 2006
    3063
    Mari-Tool lists both mm and Imperial sizes:
    ~$13 each. I have a set of their ER-20 collets and they seem to be very good quality.
    Mike
  1. ER16 Collets -- Best bang for buck?
    By cwm9 in forum Benchtop Machines
    Last Post: 11-04-2008, 08:45 AM
  2. Kress 1050 and ER16 collets
    By K.J.Everest@blu in forum CNC Wood Router Project Log
    Last Post: 07-24-2008, 12:13 PM
  3. Wanted to Buy / Borrow - 1/8" ER16 Collets in MA
    By chip_slinger in forum Want To Buy...Need help!
    Last Post: 04-05-2008, 03:27 AM
  4. Anyone have a Spec sheet on ER16 collets
    By barbque in forum Uncategorised MetalWorking Machines
    Last Post: 02-07-2008, 09:19 PM
  5. ER16 collets
    By Astroguy in forum Benchtop Machines
    Last Post: 05-26-2007, 08:05 PM
