Cutting oval not circle problem
Hi Haroonalvi,
I use a MPC03-LV control card and I agree, it is not the easiest to use. However, your problem sounds like the X and/or Y axis pulse settings are not correct. Check your settings both axis ..... Even if the circle becomes oval shaped in the Y axis, it could be due to X axis puls setting being to "small".
For reference, my laser's pulse unit settings are the same for both X and Y axis, (0.0063500000), even though on my table, my X is 500mm and my Y is 300mm
Hope this helps.
David
DBTechServ Laser Systems LLC
