586,024 active members*
4,243 visitors online*
    Sep 2004
    16
    Single Line Fonts
    This may not be the place to ask this question, but I am somewhat lost in this forum.
    I have a cnc plasma cutter which I use to cut text,etc. Recently I finished a cnc router running Mach2. I am trying to locate a single line type font to use with it.
    I notice on www.luberth.com there are some examples from Gravomaster, whoever that is.
    Does anyone know where there is a single line font available cheap?
    Dick Shuford
    Pleasant Hill, La
    Oct 2004
    40
    Single Line Fonts
    Dick,
    I haven't been able to find very many single line fonts.
    But I've had many customers that needed the Single Line Font look. So what I've done to get around this problem, is lie to the software. I choose the font. Then find the narrowest spot of the font i'm going to use, and measure this width. And I use this measurement as the tool diameter (and your tool should be this size physically or any diameter down to half this measurement). I then just create a pocket inside each letter and usually it will only need to make one pass on the inside of your text.
    Donald
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 05-19-2021, 11:26 PM
  2. Visual Basic Controller Project
    By dwwright in forum Visual Basic
    Last Post: 04-16-2016, 10:31 AM
  3. single line fonts?
    By balsaman in forum Uncategorised CAM Discussion
    Last Post: 02-18-2006, 06:51 PM
  4. Single Line Font?
    By squarewave in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-30-2004, 01:03 AM
  5. Single line mode works well, Auto is not soo good??
    By Darc in forum CamSoft Products
    Last Post: 10-26-2004, 09:29 PM
