Don't see too many of these around here. I've been slowly trying to build a cnc 'cutting tool' for a couple years now.
At one point I had built my own stepper controller and had a very ugly x/y table built out of wood with skateboard bearings, 3-18 lead screw and 51 oz-in motors....Yeah that didn't make it very far, but I continued reading and slowly saving up to start building something more useful.
A few months ago I bought a HF X1. I was looking for a little mill to play around with and well, it certainly was cheap. I've used it quite a bit over the last few months, not doing anything in particular just making little things here. Its limited capabilities make working on any mid-sized part an exercise in patience and endurance. It may be slow but its capable of what I would like it to do (at least for the time being).
Well, I finally decided to start converting this thing, I've ordered the 3-axis Hobby CNC Controller, and 3x 277 oz-in steppers. It'll be driven with EMC2 used it in the past with my own stepper controller so I know how to set it up. I should start getting parts later this week.
So, the first thing I've done is clean and fully tune the mill to the best of my abilities so far. I've torn the entire mill down and cleaned all the ways and regressed them as well as partially lapped the steel gib strips against a surface plate. Didn't do much to them, just smoothed them up a bit. After re-assembling the mill I went ahead and measured its backlash. I did not measure the Z-axis since I'll probably have to do some more work on it later, I'm not sure if 277 oz-in motors will be able to drive the z very well so I may need to get a gas-spring or build a counter weight.
Anyways the backlash on the x-axis is about 0.004", and the y-axis is about 0.005". This is on the stock screws, I do not really plan on replacing the stock screws as that seems to be more trouble then its really worth for such a small machine. 5 Thou doesn't seem too bad for the stock screws at all really, and I'm quite happy with it so far (but less backlash is always a good thing).
Going to try to keep a bill of materials running along so far (everything in USD):
HobbyCNC Driver: $79
3x Nema 23 277 oz-in Motors: $27.50 a piece ($82.50)
24v, 6.5A Power Supply: $24.95
6' Parallel Cable: $3.95
Total so far (excluding shipping): $190.40
On the 'To Do List':
Shaft Couplers (Probably spider/lovejoy type couplers)
Aluminum Stock (To build the motor mounts)
Misc Hardware (Nuts & Bolts to shove everything together)
