My question might be stupid but after reading a lot still not sure how things should work.
I'm looking at buying 3 steppers rated at 3Nm (around 430oz) - 4.2Amps in parallel and 2.1 Amps in series ?
I'm puzzled by the following - if I want to run them in parallel would I need a Gecko that outputs at least 4.2 AMps ? Or the output of the drive should be at least 2.1Amps (which the G250 will work fine)
Thanks.
