585,754 active members*
4,225 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > New guy here - Best type of drill bit for expanding (boring) a hole in brass?
    Dec 2008
    I need to do a production run of parts where I will be expanding (boring) the diameter of holes in solid brass. I will be going from about 0.19" to 0.23". The holes are about 1.5" deep. I heard that brass is hard to drill as it binds a lot. What is the best type of drill bit to use?
    Thanks, and I'm excited to be part of this forum.
    Apr 2004
    353
    If it's on a CNC, you should be ok using a regular HSS drill. If you're doing these on a drill press you can remove the positive rake on the drill using a honing stone or a grinder to make it so it won't grab the material as bad. You can also look for a straight flute drill.
    Mar 2005
    1136
    anyone who tells brass is difficult just doesn't know what they're doing, brass machines like butter....but like kaka said you have to make sure all cutting tools have zero rake.
    here's some pics on what that looks like at the end of a drill. I keep sets of #, letters and fractions ground for brass as its a pita to have grind one back for steel
  1. boring a hole thats off center
    By nmcdairmant in forum MetalWork Discussion
    Last Post: 11-02-2008, 07:22 AM
  2. Replies: 9
    Last Post: 02-11-2008, 05:54 PM
  3. Replies: 47
    Last Post: 02-01-2008, 08:32 PM
  4. Boring a Hole in 4140 steel
    By ricotututi in forum MetalWork Discussion
    Last Post: 10-06-2006, 05:15 AM
  5. Brass CDA360 Material Hole Finishing Problem
    By TCLB in forum MetalWork Discussion
    Last Post: 12-20-2005, 02:26 AM
