585,997 active members*
4,844 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Ferroresonant transformer for power supply?
    Aug 2005
    828
    Any one here have experience with ferroresonant transformers and if they will be good for a power supply to drive Geckos?
    Dennis
    Mar 2008
    24
    I have used them in cable tv networks. These are usually either 60 or 90Vac output. They have the benefit of stabilising variations in load and input voltage, often up to +-10 percent.
    Current capability is often in the tens of amps. Bear in mind that the output voltage is usually more or less square wave, so the rectified output voltage will be much more than a sinewave supply of the same voltage. (Close to the peak voltage of the square wave actually)
    Provided that the rectified voltage suits your Gecko drives there should not be a problem using them.
    Bear in mind one strange operating effect: if you use them under partial load, i.e. well below their rated current capability they tend to run hotter and noisier than on full load!!(this is to do with the circulating energy in the resonant section, but should not be a show stopper)
    Jan 2009
    265
    Just built one from a $25 flea market arc welder, it gives 62 volts and 40 amps.
    Beat that for lunch money!
    Feb 2010
    119
    there is some information on cnc home page on rewinding a microwave transformer.
  1. Microwave transformer built power supply
    By TinkerDJ in forum CNC Machine Related Electronics
    Last Post: 04-30-2021, 02:57 PM
  2. Transformer for servo motor power supply
    By robhrzic in forum Servo Motors / Drives
    Last Post: 06-12-2020, 09:49 AM
  3. Transformer for power supply for G100/G320
    By jamma in forum CNC Machine Related Electronics
    Last Post: 09-22-2006, 08:13 AM
  4. Power Supply Transformer Question
    By snooper in forum CNC Machine Related Electronics
    Last Post: 07-30-2006, 10:38 AM
  5. control transformer to power supply?
    By bobleecnc in forum CNC Machine Related Electronics
    Last Post: 05-20-2006, 02:42 AM
