585,712 active members*
3,935 visitors online*
Results 1 to 11 of 11
    Dec 2008
    Question SHM0609 lubrication
    Hi
    This is the first time I have posted on this forum but have read much about the Exitech machines.... so much so that I bought one.
    The machine arrived well packed and worked straight for the box.
    I cleaned the slides and threads and then greased them.
    But is there anyone out there who knows how to lubricate the slide block and nuts. I cannot find any grease or oil points?
    Aug 2008
    12
    Quote Originally Posted by carveit View Post
    Hi
    This is my first post here too, I can't answer your question, but I have just bought the same machine as you (mine should hopefully arrive mid-january.) I also went with exitech after reading all the information them here.
    I'm new to cnc and will be using the machine to create molds for making composite parts for model aircraft.
    If you have any pictures of your machine I would be really interested to see them, as I only have the pictures on the excitech website to go from.
    Dec 2005
    35
    i found the quickest way to grease the nuts in the future is to make sone grease nipple extentions. you get some small copper pipe and thread one end and to the other you braise a grease nipple to it. you then have to remove all the bolts holding in your ball nuts and slide your gantrys away from the nuts. screw in the pipe to the ball nuts put the gantrys back on to the ballnuts and bend the copper pipe so it clears the gantrys and rebolt them in place. now you have got a greaseing point that is easy to access.
    will post photos tomorow of the finished bits.
    Richard
    Dec 2005
    35
    here are the photos
    Richard
    ps there are some threaded holes on the side of the ball nuts for grease nipples but for some reason the factory dont put grease nipples in them when they ship your cnc. these are what you thread the copper pipe into.
    Dec 2008
    Thanks Richard
    That looks a neat solution... Thanks for the pics.
    There are grease points on the bed rail blocks but they appear to be hex brass with a domed end. Do you use a normal grease gun? or have you changed them to standard?
    Nigel
    Dec 2005
    35
    i oil them thought about changing them to grease points but thought it is going to be dificult to clean later so i oil them daily. use a standard grease gun on all the other points
    Richard
    Dec 2008
    Hi
    If i understand you correctly... you are pumping oil into the slide blocks?
    Nigel
    Dec 2005
    35
    yes
    i also put a squirt of oil on its rails
    Richard
    May 2009
    5
    What kind of lubricant is recommended for the rails and the screws?
    After doing the initial cleanup, I used MoS grease on both the rails and
    the screws. Is this best-practice?
    Regards, ray
    1050
    http://www.cnczone.com/forums/showpo...&postcount=214
    Folks - this is what I did to solve the lubrication issues - this was also used in one of my friends chinese machines and he is very happy with it - cost will be about 200USD (in India) with labour, if do it ur self might be much cheaper.
    RGD's
    Irfan
    Oct 2006
    461
    I've just gone through the lubrication for my SHM0609. For those interested... I posted up info and pictures on what I did in the following thread, post #16
    http://www.cnczone.com/forums/showth...839#post740839
  1. lubrication of meldas 64
    By nabil_elbadri in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-14-2008, 05:00 AM
  2. ADDING BED LUBRICATION
    By thegeekineer in forum Benchtop Machines
    Last Post: 12-21-2007, 03:51 AM
  3. MM lubrication concern
    By cn00728 in forum Haas Mills
    Last Post: 10-02-2007, 06:13 AM
  4. Lubrication
    By bohica in forum Charter Oak Automation Support Forum
    Last Post: 04-29-2007, 07:13 AM
  5. Lubrication
    By BeerFizz in forum Benchtop Machines
    Last Post: 11-10-2005, 01:25 AM
