I wonder if some one can help me to find information about this motor.
data sheet/specification
Model: E660
Part no: 0660-37-059
Costom part no: 5D65951H01 rev:J
Tx
Hasse
Model: E660
Tx
Hasse
Is there nobody out there that have info?
Hasse
Reliance Electric DC Servo motor Model E660
NEMA 34 Frame
Back EMF Constant, ke = 65 V/kRPM
Torque Constant, kt = 5.5 lb-In/Amp
Nominal Speed Rating: 1750 RPM
Nominal Voltage Rating: 120 Volts
Encoder;
HEDS-5605 A06 500 cpr
-05 winding option,
11.42 Ohms winding resistance, and an 8.1 A Max peak
current. 5.5 In/Lb / amp x 8.1 A = 44 In-Lb or 717 In-Oz.
Thank you. what I see is that the encoder appears to be from Avago Technologies, on my motor, manufactured by Renco.
p/n 77676-312
d/c 9852
Hasse
You should be able to get the encoder info from the Renco site.
Al.
Albert E.
Can this really be correct? 11ohm winding resistance on a size34 motor sounds like A LOT. You'll drop 92.5V across the winding when pushing 8.1A thru it, with a 120V supply there won't be much left to actually turn the motor.11.42 Ohms winding resistance, and an 8.1 A Max peak
Any data on the continous current rating?
I'm not saying the data is incorrect it just doesn't "feel" right....
/Henrik.
I have 5 winding variations listed in my ancient Electro-Craft book. They range from 0.44 Ohms to 11.42 Ohms. These motors (at least when made by Electro-Craft) had a dash number following the main part #. So, it would be something like E-660-01
Imax is peak current, not max continuous current.Code:Winding # -01 -02 -03 -04 -05 Kt 13.2 27.6 44.2 66.1 88.5 Oz-In/Amp Kv 9.76 20.4 32.7 49 65.5 V/1000 RPM R 0.44 1.28 3.00 7.1 11.42 Ohms Imax 54.2 26 15.8 10.7 8.1 Amps
Jon
Thanks Jon,
It's probably correct then. Don't know if I would like to use it though.....
I know Imax is peak and not continous, that's why asked if there was any data listed for continous current ;-)
/Henrik.
I have the information for the 0660-07-074, I am not sure how close the specs will be to yours.
Al.
Albert E.
Thank you for your interest. the problem was in the encorder. A new one is ordered. The specification does not work on my motor
/Hasse
