I had a gentle crash today (bent a reamer), and if you are going to have one I like the gentle ones. The problem was H00 as the tool length offset in my post. There is a setting on my Haas that checks to be sure the tool number and the offset numbers agree and I know it used to work because it has stopped simulations a few times for me with a warning.
Today it did not work and I can't figure out why. I ran the program below in simulation several times and the warning never came on. I have not changed anything in the post my CAM software outputs but obviously something has happened.
I thought one safety measure would be to put a large value in the length offset column for H00 but there is no 00 in the Haas length offset table. Viewing this fact I wonder where the Haas was going?
The real problem is, what is in my post, or what setting has changes that would disable the warning from coming on in a situation where it obviously should?
N20T7 M06 (0.15INCH DRILL, 135 INC)
N21G10 L12 G90 P7 R0.15
N22G90 G80 G40 G54
N23S800 M03
N24G43 H0
N25/M08
N26G00 X-0.625 Y-0.625 Z0.02
N27G01 Z-0.5 F14. S800
N28Z0.02
N29G00 X-14.875 Y-8.125
N30G01 Z-0.5
N31Z0.02
N32M09
N33M01
N34M30
I'm a bit of a slave to my CAM program so when things like this come up I'm in trouble. I thing the problem is with the Haas and I thought this was the place to find out.
