585,685 active members*
4,901 visitors online*
Thread: g83 problem
Results 1 to 13 of 13
    Dec 2008
    39
    g83 problem
    i have a multicam router
    having problems with g83
    material top 1
    surface is 0 (bot. of mat.)
    safe rapid 1.5
    peck dis. .5
    total peck depth .875
    problem is it drills to .125 1st
    then raises & pecks back down to .125
    i want it to peck on the way down
    can anyone tell me what to change to make it happen?
    ex:
    G75
    G97 S2000
    G00 T14
    G00 X2.2201 Y4.1962
    M12
    G83 R-1.25 Z-0.125 D-0.5 F0.833
    M22
    G00 X5.1576 Y4.1962
    M12
    M22
    G00 X8.2826 Y4.1962
    M12
    M22
    thx
    mike
    your r value is deeper than your z value , your drilling in reverse , lucky your cutting wood , steel wouldn't be so forgiving
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Dec 2008
    39
    no i think that part is right
    it clears the part just fine
    remember i am working from the bottom up
    thx
    mike
    Dec 2008
    3108
    Quote Originally Posted by basswakr View Post
    material top 1
    safe rapid 1.5
    peck dis. .5
    ex:
    G75
    G97 S2000
    G00 T14
    G00 X2.2201 Y4.1962
    M12
    M22
    G00 X5.1576 Y4.1962
    M12
    M22
    G00 X8.2826 Y4.1962
    M12
    M22
    Your values in the g-code are incorrect
    G73 = peck cycle ( keep pecking until Z value is reached )
    G83 = deep hole peck cycle ( full withdrawal after each peck )
    X Y = co-ordinate of hole
    Z = final depth of hole
    R = retract plane ( must be higher than Z )
    D = peck depth ( -ive )
    F = feedrate
    your code should be
    G83 R1.25 Z0. D-0.5 F0.833
    you also can have
    G83 X8.2826 Y4.1962 R1.25 Z0. D-0.5 F0.833
    machine will rapid to XY
    then rapid to R
    peck drill from R to Z in D increments
    rapid back to R
    depending on machine settings it may go higher to it's initial level
    Dec 2008
    39
    alright
    i must have more wrong here with my post
    i took the - off but now it just drills with no pecking.
    any more ideas ?
    thx
    mike
    Jun 2008
    1511
    problem is it drills to .125 1st then raises & pecks back down to .125. i want it to peck on the way down
    What do you mean it drills to .125 + or -? With a G83 cycle it feeds your pick then returns to the R-plane after every pick. So if it is feeding to .125 which you have set as your Z I would suspect it does not like that. I have never set up a part this way. I would assume a lot of your problem is calling Z0 the bottom of the part then trying to manipulate your Z and R to accomodate to drill properly.
    What is your initial Z move? Are you telling it to go Z(+#) above the part??
    Stevo
    Dec 2008
    39
    ok thx for all responses so far , getting a lot more help than i expected
    found the problem i am missing the Z after my G00 X2.2201 Y4.1962
    G75
    G97 S2000
    G00 T14
    G00 X2.2201 Y4.1962 add this (((Z-1.5))) this makes it work right any ideas?
    M12
    M22
    G00 X5.1576 Y4.1962
    M12
    M22
    G00 X8.2826 Y4.1962
    M12
    M22
    any idea what to change in my post to make it add that?
    thx
    mike
    Jun 2008
    1511
    That's why I asked about your initial Z level. The initial Z point is the position of the drilling axis when the canned cycle cancellation state is switched to the canned cycle mode. This Z position is needed before you switch to canned cycle mode.
    You can return to the initial point level with a G98 or the R point level with a G99.
    Stevo
    Dec 2008
    39
    stevo
    u r correct
    but where do u add that in the post?
    Jun 2008
    1511
    Quote Originally Posted by stevo1 View Post
    I apologize I did not really spell it out. But that is what I meant by your first Z position. I should have just stated you need a Z move before going to canned cycle. Sorry.
    Stevo
    Dec 2008
    39
    ok thx for all the help
    got it fixed
    post outputs correctly now.
    M90
    G90
    G70
    G75
    G97 S1500
    G00 T1
    G00 Z-1.5
    G00 X6. Y6.
    M12
    G83 R-1.25 Z-0.25 D0.25 F1.667
    M22
    G98 P147 D1
    M02
    Dec 2008
    Mike,
    It was interesting reading your thread today as I was going through the same excercise but was unable to post as it took about 6 hours to get my registration through.
    I am surprised your code is working as it is not working on my machine. I too have a Multicam machine and am wondering what is different from your machine to mine.
    I have been programming for our Multicam machine for about 5 years now and just today decided to try to use the G83 canned cycle and cannot figure it out. I may be able to shed some light on Stevo's remarks...
    Mike has mentioned that we are working form the bottom up...Multicam for whatever reason, works where negative values are above the table and positive values are below. This is backward from all other machine manufacturers I have seen. This situation makes it very difficult to get help from anyone but Multicam or other Multicam users and Multicam is not very good at support of G Codes, IMHO...
    I am actaully re-writing some software I wrote a few years ago that generates the code for our machine and I am hoping to market it soon. I had written my own "Peck" routine using G01 and G00 commands and just decided to try the canned cycle. I figured why not use short hand if I can.
    Here is my code using G83 to drill 1 hole...
    (Date 12/16/2008)
    (Path D:\Hal's Stuff\My Documents\Drawings\1100\)
    (Name Point)
    (Home = X110.000 Y13.000 Z-8.000)
    (Clear Level = -1.250)
    G90
    G75
    G00 T2 (1/4" Drill Bit)
    G97 S5000
    G00 X4.000 Y4.000 Z-1.250
    (BeginContour 1)
    M12
    G83 R-1.125 Z-0.250 D0.250 F0.833
    M22
    (EndContour 1)
    G00 Z-1.250
    G00 X110.000 Y13.000 Z-8.000
    G90
    G97 S5000
    M02
    As you can see, my values are similar to yours. My material is 1" thick and I am trying to drill a 1/4" hole to within 1/4" of going through my board. I am asking that the peck cycle return to a level of 1.125" or .125" above my material between pecks. I am wanting the pecks to take out .25" of material each.
    When I look at other controller (fanuc) code, all 3 of these values (R, Z and D) are positive so with Multicam saying negative numbers are above the table it is hard to distinguish what if any vales need to be positive for the cycle to work. Making all 3 values negative makes the machine continue to move "up" higher and higher after each cycle and does not end until it max's out.
    If I might ask, could I get you to copy this code into a file and see if it works on your machine? If it does, I might need to see if there is a new post processor I need to make my machine understand this canned cycle.
    My machine kind of pecks, but it moves down to the bottom level of .25" with each peck....wrong!
    In addition to this, I need to figure out how the G83 cycle should work in the case we want to use "relative" or G91 mode in lieu of "absolute" code or G90.
    Thanks for any help that might come my way,
    Hal
    Dec 2008
    39
    morning hal
    ran your part on my machine & all ran fine
    you probably need to change a few things in your post
    send me your e-mail & i will send u my post to try.
    mike
  1. machine problem or software problem?
    By bcnc in forum Syil Products
    Last Post: 10-26-2009, 03:51 PM
