585,942 active members*
3,358 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Revolutionary Linear Drive System
View Poll Results: What is your prefered high precision linear drive system?
Voters
248. You may not vote on this poll
  • Ball Screws
    159 64.11%
  • Rack And Pinion
    33 13.31%
  • Linear Motor
    21 8.47%
  • Lead Screw
    22 8.87%
  • Nexen's Roller Pinion System
    12 4.84%
  • Other
    15 6.05%
Multiple Choice Poll.
Page 4 of 4 234
Results 61 to 75 of 75
  1. #61
    Re: Revolutionary Linear Drive System
    overall beyond an interesting approach, its expenses, and way less effective than already in use solutions.
  2. #62
    Jun 2007
    19
    If somebody was to provide the maths required to create the curve of the rack, and output it to a DXF, would people cut there own? Another thread on here discussed the cycloid gearbox and making your own. Seems people were very interested in that....and guys created a program to spit out the profile in DXF. I love the way the pinion is easy to make in this system.
  3. #63
    I already did that. I created an AutoCAD macro to create the rack profile, and cut a sample from Plywood. Then I decided to use helical R&P instead. I need to try to sell these roller pinions I have in my drawer.....
  4. #64
    Sep 2006
    6463
    I think if you apply an accumulation factor to any measuring device then provided the series of objects that make up the accumulated length each do not vary more than .01mm then the accumulated measurement overall will be very accurate indeed.
    This means if you have rack sections 12 inches long and they were precision ground on their ends to within .001" each then who needs the expensive Nexen type R&P when your 20 foot rack would only be out by as little as .020" maximum......guaranteed.
    I doubt that anyone (at home) has the capability to measure or check a measurement of 20 foot to within .020".....at the same time any work performed on such a machine would be accurate to within .001" for every 12 inches.
    Many years ago I worked with an inside tubular stick micrometer that measured 2 metres in 600mm lengths....it had a calibration certificate from a metrology company that guaranteed the overall accuracy.
    As that is an achievable factor, then a segmented rack will be in the same category provided the butted ends are in close contact.
    It just means the pinion must make metal to metal contact (spring loaded etc) with the teeth tightly meshed in the rack to eliminate backlash......who expects to get that accuracy on a big DIY CNC router anyway.
    Ian..
  5. #65
    I believe that the Nexen racks come in 1 meter lengths, with a jig to mount them with the correct spacing. They probably have a small gap between them.
  6. #66
    Jun 2007
    19
    Any chance I could get my hands on the macro? Never used one in Autocad so it should be fun. I did read most of the pages of the post, I must have missed that part of it.....
  7. #67
    I can't seem to find it. I may not have saved it when I got a new PC. Here's a drawing I created with it.
    Attached Files Attached Files
  8. #68
    Jun 2007
    19
    Shame, that DWG doesn't help with the design of the rack, and the shape of the curve of the teeth. Thanks anyway.
  9. #69
    I used that drawing to cut a sample.
    It just needs to be trimmed, as each tooth is a little long at one end.
  10. #70
    There are different sizes of Nexen rack and pinion, and this is only good for one size.
  11. #71
    Jun 2007
    19
    The DWG that you sent has this;
    Attachment 399782
    That the pinion, not the rack....
    So to get the rack, you rotated the pinion multiple times and took snapshots?
    - - - Updated - - -
    Ohhhh ****e...sorry I didn't zoom out.....
  12. #72
    Jun 2007
    19
    So your macro rotated the pinion and took multiple snap shots to create the path of the teeth, and make spline with those co-ords. I guess you could have stipulated the "resolution". However, I think that this type of operation would not result in linear motion that is proportional to the amount the motor rotates.
    That is because at this part of the curve;
    Attachment 399784
    the pin in the pinion is not moving at the same proportion as the profile of the tooth. I might be wrong, but I've seen this curve in cycloid gearboxes, and they don't provide constant velocity inside each revolution. I'll have a play with this and see what gives, much appreciated for what you have done.
  13. #73
    It basically rolled the pinion, and tracked the center of the rollers. I don't remember the exact details. In the section you highlighted, the segment lengths are about .02mm.
    I then offset this path by the radius of the roller, and converted the straight segments to arcs to smooth it out. It's not 100% perfect, but I think it's very close. It would have been fine for what I was going to use it for. It rolls very smoothly over the test rack I made.
  14. #74
    Aug 2005
    128
    Nexen gives out the rack DXF on their site.
    Ger21, you still have those roller pinions?
  15. #75
    No, sold them about 6 months ago.
Page 4 of 4 234
  1. Replies: 0
    Last Post: 07-27-2013, 06:29 AM
  2. Interesting Linear Drive System
    By TravisR100 in forum DIY CNC Router Table Machines
    Last Post: 01-17-2007, 06:01 PM
  3. new linear drive system
    By rceebuilder in forum Open Source CNC Machine Designs
    Last Post: 08-21-2006, 06:22 PM
