I am in the processes of redoing the electronics on a old router. I am trying to reuse many of the components, including most of the power supply.
The primary of the transformer has inputs for 220 v phase and 0 v (i assume this is the neutral)
The trouble is that the household electrical connection (outlet) I was thinking of using was originally put in for a welder and has two prongs at 120 and one ground/ neutral. So how would I get 220 and 0 from these two?
I have the old router manual and it says the machine wants 220 vac /50-60z 1500w and that it should be hooked up with a phase wire, neutral wire and ground wire connection.
Thanks for your help!
Justin2
