585,942 active members*
3,345 visitors online*
    Feb 2006
    35
    Unhappy NEED HELP SERVO ENGAGE
    hi
    i vave had my plasma table runing for 6 monts on belts
    and decided to go for rack & pinion drive. all worked fine until my servos do not engage anymore .
    I have a buton on my controller (logitroll 20 amp ametek servos )that if i push up for 3 sec it engages (activates ) the servos or from active mode if pushed down dectivates the servos.
    when my computer is of or if i unplug the parallel cable from computer ,i can activate the servos everything is ok
    but when the computer is on (does not mater if mach is runing or not)the servo do not engage.
    when i push the buton to activate the servos they try to move and deactivates
    or if i keep the buton presed the 3 axis move rapidly and get deactivatad and move again (hi speed very short moves ) :drowning:and so on until i release the buton.
    there is another situation when i unplug the parallel cable, activate the servos then plug back the cable and play whit it lyke everything is ok
    Feb 2006
    35
    the xml file
    Attached Files Attached Files
  1. 'Jumpy' servo motion; NUM servo and drive.
    By ralph@nes in forum Servo Motors / Drives
    Last Post: 08-24-2010, 04:34 PM
  2. Matching a servo drive to a servo
    By 69owb in forum Servo Motors / Drives
    Last Post: 02-04-2009, 04:00 AM
  3. Sell Servo Motor, Servo Drive by GSKcnc.com from China
    By salecnc@hotmail in forum News Announcements
    Last Post: 06-03-2008, 08:55 PM
  4. Pluto Servo - Motors won't servo correctly????
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 01-10-2008, 09:34 PM
  5. Servo drive / Servo Amplifier
    By Ken_Shea in forum Servo Motors / Drives
    Last Post: 07-10-2007, 11:12 PM
