585,760 active members*
4,019 visitors online*
Page 2 of 2 12
Results 21 to 30 of 30
  1. #21
    Feb 2007
    10
    personaly i think it is a pice of garbage it is easyer to program your part contours by writing a program or select a program copy it and edit to your needs.but i only run a HAAS SL30 B.B. with 15" kittagawa chuck.
  2. #22
    Jan 2006
    4396
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
  3. #23
    Jul 2007
    skewed parts
    Hi all,
    Using Visual Quick Code and the VOC Probe System, can you use this to tell if a blank or slab is out of square or skewed on the mill table? By probing twice along the lengths of two sides, can the probe tell how far off the part is and either send an alrm or ultimately, compensate for this and match the milling program to the skew angle? That would be nice!
    Bob
  4. #24
    Jun 2007
    Cool VQC Templates
    Here is a version of VQC with additional templates to finish slot in X and in Y axis. I've proven it out and all works well. Enjoy !
    Attached Files Attached Files
  5. #25
    Jun 2007
    The Haas probing system will adjust for these issues. But you must use the G65 command in your macros.
  6. #26
    Dec 2006
    9
    I just started writing some VQC for HAAS TL2 and SL20. I actually used local macros in the output of the code so in the VQC you only have to enter O.D, Pitch and Z depth to cut a thread very close to size the first time. Nice not to have to calculate each thread every time!
    Jet engine is next!
    http://www.floridaame.org/GalleryPages/g1m0186.htm
  7. #27
    Jan 2006
    4396
    Quote Originally Posted by Chi-town CNC View Post
    It is a convenient Tool
    Toby D.
    Schwarzwald
  8. #28
    May 2009
    5
    Could somebody help me with VQC for windows to make some templates , I am trying to get it , but i don't have any luck.
    It could be a big help for me if somebody would help me with it. My email is [email protected].
    Szyle
    Romania
  9. #29
    Jan 2011
    380
    Quote Originally Posted by XPythonX View Post
    I know this is an OLD thread, but THANK YOU! You saved me. Someone wiped out my template file on machine
  10. #30
    Feb 2014
    thank's for help :")
Page 2 of 2 12
  1. parametric programming
    By Karl_T in forum CamSoft Products
    Last Post: 05-24-2005, 08:58 PM
  2. HAAS Indexer Prodramming / Control
    By CAMmando in forum Haas Mills
    Last Post: 06-10-2003, 04:22 PM
