JUST PURCHASED A USED LB10M. CAN'T SEEM TO FIGURE OUT HOW TO DELETE PROGRAMS...
ALSO, HAS ANYONE HAD PROBLEMS WITH COMMUNICATION? I CAN SEND PGMS TO THE DESKTOP, BUT NOT FROM THE DESKTOP TO THE MACHINE...
for deleting , edit>delete *>write - this should delete all programs one by one
or
edit>init>write -delete all programs in one shot
for the transfer , br sure that your file got th $progname.min% at the start and the % at the end and every character got to be in CAPS, the osp700 dont support small character
on the controller . edit>PIP>read>write or edit>PIP>readTT>write
hope this works for you, data transfert is a bit tricky on okuma controler
If you use DELETE * you will delete all programs WITHOUT confirmation.
If you use DELETE *;V you will get the Delete Confirm message for each file.
Ah, We have a couple of OSP7000 controllers and I thought that it was still applicable, however, always willing to concede that it may be different on the OSP700.
If not, wel you you now have the method I have used to get the machine to confirm the delete or not.
