Originally Posted by
Spunk
i think i need ubuntu with EMC2 to do that?
now i have the standard issue EMC debian from sherline...
Any linux distribution worth it's salt includes python.
That wiki page has grown since I last looked ! The problem is it assumes people know what python is and how to use it. What percentage of the population might that be ?
Do this:
1) Right click "upload arcbuddy.py" on that wiki page.
2) "Save link as" and save it to your home directory
3) Open a terminal and type the commands
Code:
chmod a+x arcbuddy.py
if you get a "bad interpretor" error, open arcbuddy.py in a text editor and modify the top line to read
and rerun the ./arcbuddy.py command in the terminal.
4} That's it. These scripts should also work in Windows with a python interpreter ? Think so anyway.
Btw: There's a quick text editor that can be run right from the terminal.
The instructions are all listed at the bottom and take the form
Code:
"cntrl btn" "some letter"
very handy and intuitive.
Anyway, just me up much to early and rattling on. Hope that helps in someway.
Edit/ There is a possibility another error might pop up. Depends on the python installed and what the gcode generator calls up. If another error shows up, just paste it here and someone will tell you what to install.
Anyone who says "It only goes together one way" has no imagination.
