585,712 active members*
4,329 visitors online*
    Mar 2007
    100
    rigid tapping on mini-mill
    Does anybody know how you tell if the rigid tapping option is available on a mini-mill? If it is not available is that an option that can be turned on (I'm assuming it's already in the software).
    927
    Parameter #57 > Rigid Tap..value of "1" in on.."0" is off...
    Yes, it can be turned on with a codefrom Haas, after it purchased..
    Sep 2006
    81
    If it's got a 0 in parameter 57, it's off and you need a code to turn it on. If it says 0T, you have a 200 hour trial (if that trial has been partially used, you have some amount of time less than 200 hours)...if it says 1, you have rigid tapping.
    Jul 2005
    12177
    When you have rigid tapping turned on you can also do repeat rigid tapping but this has to be turned on also. It is a setting on some machines and a parameter on others (I think).
  1. Replies: 24
    Last Post: 05-01-2014, 07:02 AM
  2. Tapping head or rigid tapping
    By Gregory_C in forum Syil Products
    Last Post: 10-18-2008, 06:49 AM
  3. Rigid tapping on Haas Mini Mill
    By rrossey in forum Haas Mills
    Last Post: 03-16-2008, 03:29 AM
  4. Mini Mill can it repeat rigid tap?
    By Loading in forum Haas Mills
    Last Post: 09-12-2007, 03:26 AM
  5. Rigid tapping or tapping head
    By kentavv in forum Charter Oak Automation Support Forum
    Last Post: 09-24-2006, 06:08 PM
