I've got 4 panels to mill from ALI 3003 0.09 thick.
Mill is a CNC'd X1 with a belt drive. Spindle speed up to 8000RPM, feedrates up to 15IPM, (rapids are set at 20IPM, and I could maybe get 25IPM if needed). tool is 1/8" HSS endmill. mist cooling is available
looking for help on feed per tooth (IPT) & cutting speed (SFM). I can do the math for speed & feed...
thanks in advance
Les
