585,978 active members*
4,298 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hitachi Seiki Service and Support!!!!!!!!1
Page 4 of 11 23456
Results 61 to 80 of 208
  1. #61
    Dec 2008
    239
    Quote Originally Posted by cncrepairs View Post
    Dear All
    I have a hitachi machine and facing following problem ,can any one help me to get a soft copy of pc ladle. following are the details.
    Problem -- PLC DATA LOST ON HITACHI SEIKI HG500
    Service Required -- A Soft Copy of PC LADLE.( We have a
    communication software and cable for
    uploading
    Machine Details
    Model--- HG500
    CNC ---FANUC 15 MA
    SR No --HG50229
    PLC --- Hitachi Seiki make MICON 16 II
    Specifications--- Normal
    Ladle Program No---2741-A02T(Mentioned in the electrical diagram
    book)
    cncrepairs([email protected])
    i can send give your contact details .
    Regards
    Prabhat Mishra
    +91-9430737981
    [email protected]
  2. #62
    Nov 2004
    36
    I'm back
    I would like to start by saying sorry to everyone for being away for so long, it was unavoidable.
    I am back and you can contact me on this site I will be checking it daily again. I am servicing machines again!! So hit me up
    thanks
  3. #63
    Feb 2007
    17
    very good, hitachi man.
    can you help me with a cnc hitachi maccmatic 48v?.
  4. #64
    Dec 2008
    26
    hitachi lathe
    i have a hitachi seiki lathe from '99. I want override the door settings so i can machine with the door open. Is there any way to do this?
    Also, I have a bar puller and I want to be able to open the chuck, pull the bar out, and close the chuck while a program is running. Do I have to make any changes to the settings?
    Thanks.
  5. #65
    May 2009
    Hello Josh,
    Unfortunately i am located in Poland, Europe and can't ask you to come over, so perhaps you can help me via e-mail.
    We have Hitachi-Seiki HT-15 with Seicos M II control
    The battery has been changed
    Currently we have :
    -battery alarm
    -5022,5031,5033 alarms
    -slbus table error
    No manuals of any kind available
    Any idea how to get rid of them??
    Regards, Andrew
  6. #66
    May 2009
    Hello Josh,
    Currently we have :
    -battery alarm
    -slbus table error
    Regards, Andrew
  7. #67
    Jun 2009
    Smile VS50
    Hi Hitachi man,
    Good day!
    I have a HITACHI SEIKI VS 50 milling.(Fanuc 18M)
    But the SIMENS PLC(S7-200) is bad.
    Can you send me the ladder for Simens PLC .(Not PMC ladder)
    Then I can change a new one.
  8. #68
    Jun 2009
    Smile VS50
    Hi Hitachi man,
    Good day!
    E-MAIL:[email protected]
  9. #69
    Dec 2008
    26
    hi,
    i have a hitachi seiki ht40g with a seicos A10L. I bought it in 1999. I hit feed hold during a tool change. It gave me an alarm, and I couldn't reset it, so I powered off the machine. When I powered back on, the alarm is still there. I'm getting a turret index power off (2252) alarm. Any way I can reset the turret?
    thanks!
  10. #70
    Dec 2008
    26
    fixed turret butt...
    ok so i got the alarm to go away but now the tool numbers are off... if i call up tool 5, it gives me tool 8... how do i fix that?
    manoj
  11. #71
    Sep 2008
    138
    Hi Hitachi Man
    Quote Originally Posted by Hitachi_man View Post
    thanks
    Could you tell me how to input data for Micron-8
    Regards
  12. #72
    Dec 2008
    239
    Quote Originally Posted by seawolf217 View Post
    manoj
    check the micro program correctly and if you have back up of Micro ATC programe please re load it in machine If the problem persist feel free to communicate me on [email protected] or on +919430737981
  13. #73
    Oct 2008
    32
    When starting spindle by MDI at speed 500 rpm for boring soft jaws. Alarm No 520 appears saying "Spindle start impossible, Check door close, chuck close and center position".
    Door close LED is ON, both the chuck proximity switch also ON (LED ON) i cannot find location of center position LED or proximity switch.
    How to confirm about center position . Machine is Hitachi Seiki HT20SII .
    I have its programming manuals but no operation manual. An help in this regard will be highly appreciated.
    Regards,
  14. #74
    Oct 2009
    Hello> I'm from Dominican Republic
    I have a tri-turn model cnc 4NE-II-600,
    Series # NE-42346SC. FS-NC Fanuc 3TF.
    Well the point is that the machine gives me an error that is this low parity. I know how to delete it, and I also need the parameter.
    I thank you beforehand.
    Greetings. DUARTE VELEZ ..
  15. #75
    Oct 2009
    hola hitachi man
    tengo una hitachi seki 4ne-II-600 control fanuc FS 3TF
    y me da un error parity low. por favor como resorver el errror
    SALUDOS Y GRACIAS.
    Duarte Velez
  16. #76
    Aug 2007
    138
    Did the MIB get him?
    Has anyone heard from Josh aka Hitachi man since his last post in Sept? I would love to see some posts from him. I am looking for schematics for my VK45 mill. I want to add a 4th axis to it and need some help.
    Keshka
  17. #77
    Jul 2009
    HITACHI SEIKI VA-40 FANUC 6M CONTROL spindle drive
    I got a problem with a Hitachi VA-40 the Spindle drive and motor were checked by OESS and both of them checked good but every time try to stop the spindle with M05 it gives me an OCL LED alarm on the spindle drive....Any idea what this problem might be? please email me at [email protected]
    Thank You
  18. #78
    Sep 2008
    138
    About 4th Axis
    Quote Originally Posted by Dancy View Post
    Keshka
    Pls PM for me your email
  19. #79
    Nov 2006
    303
    I have tried several times to contact him. No go. I created another thread looking for reliable service contacts. There seems to be many machines still in service yet very little support. I have a Seicos III in a lathe and looking for all the contacts I can find...
  20. #80
    Sep 2008
    138
    Need help with Hitachi Seiki VM40
    Dear all
    I have Hitachi Seicos VM40 with controller is Micron 16 MII. Battery was dead so all data was lost. Dose anybody have all data for my machine. I'm willing to buy it
    Regards
Page 4 of 11 23456
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Hitachi Seiki Parts, Support and Manuals
    By npkaye in forum News Announcements
    Last Post: 03-09-2011, 12:16 PM
  3. HITACHI SEIKI MACHINES. SERVICE / TECH
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2010, 04:49 PM
  4. Hitachi Seiki tech network - support
    Last Post: 12-29-2008, 10:26 PM
