585,926 active members*
3,669 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Hitachi Seiki Service and Support!!!!!!!!1
Page 6 of 11 45678
Results 101 to 120 of 208
  1. #101
    Mar 2011
    REGULADOR TORNO HITACHI SEIKI TF 25
    Quote Originally Posted by CyberCNC View Post
    We did in fact purchase Hitachi Seiki USA inventory when they went bankrupt (however, the owner didn't "put his house up" for collateral.) We currently offer manuals, technical support and parts for Hitachi Seiki; as well as used and new machine tools. Please call 262-662-1100.
    Tara Markiewicz for Cyber CNC Machinery Sales, Inc.
    NECESITO COMPRAR REGULADOR TORNO HITACHI SEIKI TF 25
    decirme plazo y precio llevandose el averiado
    Mi empresa esta en Madrid España
    Un saludo
  2. #102
    Mar 2011
    Quote Originally Posted by Hitachi_man View Post
    Hello all out there lost in the confusion of trying to find support for your Hitachi Seiki machines. I own a CNC Service Company in Wichita Kansas working on all brands of machines, but specializing in Hitachi Seiki. I currently have over 10 gig of info on Hitachi Seiki machines in my database from machine software to procedures and ELECTRICAL MANUALS!!!!! I have years of experience working with these machines, and until June of 04 I worked for Mori Seiki in LA as the Hitachi Seiki specialist. We DO travel, and my hourly rate for shop labor is only $75.00 per hour no matter what state your in. I also do phone support and provide procedures at $45.00 per hour 1 hour min....If you have a Hitachi Seiki machine, other machine models welcome also, call us and we will be happy to help!!! (cureing your headaches is free!!)
    You can contact us at 316-744-0549 just ask for Josh, aka Hitachi_man
    well be looking forward to hearing from you!!!
    Plazo y decirme Precio llevandose El averiado
    Mi Empresa esta en Madrid, España
    Un saludo
  3. #103
    Mar 2011
    What is Bridge Rectifier, and the function of Bridge Rectifier?
    What is Bridge Rectifier? Let's learn something first. Electricity in a home's power outlet is not in the form that's required by the circuitry inside electronic appliances. At this time, you should use bridge rectifier to change something. Power supplies are circuits made up of various components that convert the electricity that comes from the wall outlet into the various forms needed by the appliance. A bridge rectifier is a common part of those power supplies. It's a bridge-like setup involving four diodes that provides the same polarity of output voltage for either polarity of input voltage.There are something about bridge rectifier.
    Converting AC To DC
    Many electronic circuits require DC (direct current) rather than AC (alternating current), as well as different voltages than supplied through a home's electric outlet. The purpose of a bridge rectifier is to convert AC to DC, this is also the function of bridge rectifier, and to provide various voltages as needed by the bridge rectifier.
    Semiconductor Diodes
    A power supply diodeDiodes are semiconductor components that allow electrical current to pass through them only in one direction. If the polarity (the "plus" and "minus") is reversed, current is blocked.
    Bridge Rectifier Configuration
    Basic schematic for a bridge rectifier circuitWhen four diodes are placed in a certain configuration in an electric circuit and an alternating current is supplied to them, the resulting output is a direct current. This setup is known as a "bridge rectifier" because the alternating current is rectified or changed to direct current
    There’s additionally the necessity for inclusion of a voltage divide to determine optimum working voltages to the gate portals of stated multiplicity of said N-channel MOSFET means and mentioned multiplicity of mentioned P-channel means.
    The method needs to also have a element to protect the gates of mentioned multiplicity of said N-channel MOSFET means and mentioned multiplicity of stated P-channel MOSFET means from false conduction due to some unauthentic noise impulse voltages channeled to mentioned fill bridge rectifier.
  4. #104
    May 2011
    Looking for assistance with a Hitachi Seiki problem...
    We have a Hitachi Seiki HT 20 RIII ser# NR30230 with a TR-10 gantry loader. The machine is stopping in one of the macro programs that passes variable data between the machine control and the gantry control. It just stops and does not generate any error codes. Is this something you could help us with? Would you be willing to travel to Indiana to trouble shoot the problem?
    Thanks.
  5. #105
    Sep 2008
    138
    I Need electric schematic and ladder diagram of Hitachi Seiki TF-20 with Seicos L-III controller (Equipped with Fanuc Power mate E for tool change). If any body have it, I' willing to buy
  6. #106
    Apr 2009
    34
    TF20 WIRING DIAGRAM
    Thank you for your request, we have this manual in-stock and available for shipment today. Please contact me at 262-662-1100 or email [email protected] for a formal quotation.
    Original-Used TF20 Seicos LIII Wiring Manual $125.00
    Quote Originally Posted by greenery_fr View Post
  7. #107
    Jul 2011
    I am working on re-setting up the door interlocks on an HT50G. Someone did a hack job disabling them but the electrical manual only goes as far as showing input signals into the panel slave......
    Where can I find a good schematic of the entire interlock system?
  8. #108
    Sep 2011
    Hello
    my machine is:
    Hitachi seiki model: HC630 serial no: HC 3020
    i need following parts
    Gear: part no: 2685-10-226-02
    worm: part no: 2686-10-307-10
    can anybody provide me those parts ?
  9. #109
    Sep 2011
    4
    I have a hitachi seiki 203r wire edm that has a servo driver noy ready error. The machine has a Mark 10W X 2 control all the leds on all of the boards indicate the system is operating normally, but I am getting a servo driver not ready alarm. I have reset the absolute encoders and checked three of the Yaskawa servo drives with the Yaskawa motion software. There are three SDGA servo drive and two SDG servo packs, it seems that Yaskawa does not support SDG sevo packs in their software, Yaskawa says they are working on a solution for me. Has anybody run into this alarm before.
  10. #110
    Aug 2007
    793
    have you got any info for hitachi HC400 machine?
    machine equipped with micon 16-2
  11. #111
    Jan 2010
    13
    hi Hitachi Man,
    I had hitachi seiki 4NE-2. my machine had a problem with spindle its rpm is too low i gave him a command to run 3000 rpms but its runs only 300 rpm.
    How can i solved this problem? plzzzzzzzzzz help me
  12. #112
    Jan 2010
    13
    Quote Originally Posted by Kenn6eth78 View Post
    07-25-2011, 07:46 PM
    onsite Join Date: Jul 2011
    i had found the problem in micon 8 PLC in my machine. some plzzzzzzzzzzz provide my maintance manual of hitachi seiki 4ne2-600.
  13. #113
    May 2005
    109
    How to set SLBus table?
    hi Hitachi Man,
    My Hitachi VK45 (Seicos Mark II) got trouble a couple days ago. All leds on panel is lighted. I think that SLBus table got problem. Could you show me how to check and set SLBus table.
    Thank you very much,
    Jung
  14. #114
    Jan 2010
    13
    i think my machine had micon 8-1. can you plz told me about the diffenerce between micon 8-1 and micon 8-2
  15. #115
    Nov 2011
    Wink cnc machine failure
    Good day I have a problem with a CNC machine hitachi seiki v50 someone could help me system files and I have deleted someone has these files screens
  16. #116
    Dec 2011
    need to bleed hydraulic lines on hitachi seiki lathe
    Dudes, I get a motor alarm on my 3NE-300. I think it's the hydraulic unit.
    I just purchased machine at an auction. Machine ran fine. Any opinion is
    appreciated.
  17. #117
    Feb 2009
    6028
    Try swapping the phase on your incoming power
  18. #118
    Nov 2009
    71
    Trash
    Hitachi Man
    I have a HITEC-TURN 20/20-600 that I crashed and was wondering if you had a procedure to re-set the turret?
    Eric
  19. #119
    Feb 2012
    I need the Hitachi Seiki electronic's part model: SLPW-ED139 for Controller Seicos M16III. Anyone can help? Thanks.
  20. #120
    Dec 2008
    239
    ED 191
    Dear Sir,
    Please send the inquiry on [email protected]
    Regards
    Quote Originally Posted by Didik View Post
Page 6 of 11 45678
  1. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  2. Hitachi Seiki Parts, Support and Manuals
    By npkaye in forum News Announcements
    Last Post: 03-09-2011, 12:16 PM
  3. HITACHI SEIKI MACHINES. SERVICE / TECH
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2010, 04:49 PM
  4. Hitachi Seiki tech network - support
    Last Post: 12-29-2008, 10:26 PM
