Hi Prabhat Mishra,
Your out of hospital I see and alive and well! How about giving me money back. Do not deal with this guy. He strung me along for weeks.
Ed
i have a 0188 ofs interfarnce check error alarm on my hitachi hitec 20j. Does anyone know what is causing that
Hello,
Here a question from Stefan Beerens of the netherlands.
I have a hitachi seiki turning machine st200 who needs new bearrings in the main spindel. It's not built in spindel but with belts.
Can anyone give me an adres for new bearrings for this machine.
[email protected] is my mail adres.
Thanks a lot.
Best regards Stefan Beerens
Hello,
I have Hitachi Seiki VK55II machine with Seicos 10 control. Battery alarm started to appear on screen of control. I can reset alarm but it appears again every 10-15 days. I don't have proper support of that machine and I'am lack of documentation. Can you help me with procedure for battery changing?
Also need help with data backup before battery changing.
I will appreciate for any kind of help.
Hello
I have a dumb problem with Hitachi HT20RIII with Seicos L Multi + everything is in German and i cant load any program from memory to automatic mode. When i Write new program, i have it in automatic. Program from Program List loads to Prog (Edit) - background memory only - i'm selecting program from list by INPUT button.
on HiTurn200 with pcFlexi I have no problem. Program>>Program List>> select program hit INPUT and ready to go...
Please help :/
hi hitachi man,
i have HG630 HMC MODEL 1996.
I WANT SPARE FOR POWER SUPPLY BOARD CHIP.
CAN YOU HELP ME?
KARTHIK
Can anyone help with hitachi seiki vm40 errors?
bubble alarm and I am getting machine alarm which is general alarm I think.
Also a few parameters and 5097 cutting monitor alarm and 5117 N/c unit selector alarm.
Hi Josh,
I'm Tom from Phoenix.
I am having a problem clearing the X and Z axis over travel alarm on a Hitachi-Seiki TS15 using a Sigma 21L control.
So far I moved the ball screws manually off of the hard stop/limit swithes, but I can't seem to clear alarm.
I don't mean to brag, but I have over 20 years experience in causing alarms to happen, but even that hasn't helped.
I haven't cracked the electric panel yet, only because my instincts tell me "its Forbidden!"
Any help would be appreciated. I am an ex-musician. I'll give you free singing lessons via mindmeld
Thanks.
Tom
Hello!
We have a problem with Hitachi Seiki 10M.
Error is 801 PC LADDER SUM CHECK ERROR
Does anyone know solution for this?
tell me what kind of Micon you have on your machine
Hello,
if any one need any help with Hitachi Seiki's please feel free to message me. I have a lot of experience with repair, both mechanical and electrical. I have a lot of surplus parts and software available as well. Just message me with the machine model and software/control version and I will try my best to help out.
John
I have 2 problems ...
I loose on a HT40G with Fanuc 16TB with MMC IV all data
i don't have the original data sheet but i found all fanuc parameters , but all hitachi one are missing
(ssl tables )
Could you help me
On a VM40II with a seicos III control, did you already use YUYU tool ?
I know this Conpany is Good with Hitachi
www.gebert-borken.de
Can you help me
how to enter PARAMETER 9000 9900 VS50 HITACHI SEIKI?
I ripped out the seicos control and rewired everything wiyh mesa cards and linuxcnc.
Hitachi Seiki HT20SII here with Yasnac LX3 -- just got it powered up in my own shop, saw it run fine on PO's floor.
I have a couple alarms that I can't get cleared and I am suspecting my power for one of them.. 240delta is what I have going into it. I have tried switching phases to no avail.
First AL-3: Thermal Alarm
Second AL-4: Lubrication Alarm
It was jogging fine until I returned it to zero, then it spit this thermal alarm and won't do anything. Anyone have a lead on what I could do to clear this thing? Should I get it under lower power first?
Madison
thermal alarm sound like a thermal overload is tripped. Lube alarm sound like the system doesn't think it is being lubricated. Check all breakers and overload and fill up the oil
Any idea where these thermal overloads are? I have looked everywhere, reset all breakers I could find but am still getting the AL-3 Thermal Alarm.
I managed to clear the lube alarm by cleaning up the sensor in the lube reservoir. PLEASE help, I need to get this thing running.
-Madison
