585,555 active members*
3,482 visitors online*
Results 1 to 6 of 6
    Mar 2007
    11
    Cool MORI SL-3A YASNAC 2000B CONTROL
    Hello,
    I am looking for a operators manuel for a yasnac 2000b control. I am rtying to hook up a btr to send a program can`t seem to get it to work. Any help would be very much appreciated .
    [email protected]
    Thank you
    Jason:
    Nov 2008
    94
    Give some info on your BTR. the PC you are using. The software, and the Com. cable.
    It's all got to right.
    JT
    Mar 2008
    169
    Try http://www.drives.com. Go downloads - browse - by controller. When you are in the page select the cnc model.
    Nov 2008
    94
    kcho,
    The 2000B is not supported by Yaskawa on their site. They only go back as far as 2000G.
    Also, Yaskawa could care less about BTR's. They are not and were not Factory options. So there is no support from them.
    The best way to get a BTR working is either use the old Mori tech that I used. He MADE the board and gave me everything I needed to hook up the Job. Or use one of the reputable BTR manufactures in the CNC community.
    JT
    Mar 2008
    169
    The hardware is the same in two cnc models. I have to put SigmaII instead the original MR DC servos and I used the 2000G Manuals.
    Recomend Jason your tecnician.
    Carlos
    Sep 2004
    51
    I have a 2000b control and successfully use a BTR from Omega in Dallas phone 817 633 2895 ask for Tommy. The computer needs to be using windows 97 and the software runs in a DOS window. Newer Windows will not work because they use USB which is too fast. I am glad to help further if needed. You will have to make a new cable which I have done myself. I have not been able to drip feed my machine but expect it will be possible. Only recently have my programs been large enough to need to drip feed. Unfortunately, my machine is down right now.
    Could you be so kind if you have parameters below 70? My machine may have some issues with disturbed parameters versus a board problem and I am hoping to find others with 2000b to compare with mine.
    Keith Clark
    Oklahoma City
  1. Mori Seiki MV45 Yasnac MX1 Help Please
    By premier_industr in forum G-Code Programing
    Last Post: 10-21-2011, 10:59 AM
  2. Mori Seiki MV45 Yasnac MX1 Help Please
    By premier_industr in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-05-2008, 04:14 PM
  3. Mori Jr with Yasnac MX2, a little help
    By dannystooblue in forum Mori Seiki Mills
    Last Post: 09-24-2008, 04:00 AM
  4. Wiring diagram for Mori Seiki TL5 with Yasnac 2000g control
    By frank12933 in forum DNC Problems and Solutions
    Last Post: 04-21-2008, 07:30 PM
  5. Mori Seiki MV45 Yasnac MX1 Help Please
    By premier_industr in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-27-2007, 06:04 AM
