586,009 active members*
4,851 visitors online*
IndustryArena Forum > CAM Software > Surfcam > surface cutting
    Apr 2003
    18
    surface cutting
    I'm a new user of surfcam velocity. I can't seem to find out how to rough out a surface. I have a square pc of bar stock 23. inchs long. I'm trying to rough this pc out to .4 deep with a 3 inch radius. I can finish it no problem. Everything I try either gives me a finish cut or no path at all. thanks
    Dec 2008
    22
    Not really clear on the shape you are trying to rough out...if it's a cavity, did you select 3 axis,Z rough,no material, and then the tool info stuff?
    Steve
    Apr 2003
    18
    I'm trying to put a 3 inch radius right down the center of the 23 inch bar .4 deep. Yes I tried that. It seemed to generate a tool path underneath the part, then nothing. My surface arrow is on the right side because I can right a finish pass.
    Dec 2008
    22
    If you are trying to do a Z rough operation, the only way it will work is if you have a pocket shaped workpiece. In other words, like in your case, if you have a surface running down a length of material, you would need to cap the ends and then select all three surfaces, and then select "no material".
    Hope this helps...
    Steve
    Apr 2003
    637
    You can also use the auto rough routine for something like this. Just create a 3D tool path with your roughing steps leaving some stock for finish. Then use the that tool path to generate the auto rough program. In typical Surfcam fashion, you’ll have to edit some of the defaults to make it work for each circumstance.
  1. Looking for cutting tool to mill surface..
    By Sperstad in forum Want To Buy...Need help!
    Last Post: 10-21-2008, 10:06 AM
  2. Cutting a Surface plate?
    By BrendaEM in forum Mechanical Calculations/Engineering Design
    Last Post: 07-24-2007, 09:50 PM
  3. How to level out my cutting surface?
    By BrMiHi08 in forum Commercial CNC Wood Routers
    Last Post: 12-20-2006, 12:14 PM
  4. Gibbs not cutting my extruded surface
    By machinebox in forum GibbsCAM
    Last Post: 09-21-2006, 05:03 AM
  5. Cutting the bottom surface
    By lilricky2 in forum BobCad-Cam
    Last Post: 12-11-2005, 06:41 AM
