585,581 active members*
3,802 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > got Dahlgren engraver for retrofit- suggestions?
    Jan 2007
    18
    Today I got (for free!) a Dahlgren system 400 SE. The previous owner said he had some trouble with the electronics. I brought it home and plugged it all in, and can't get any movement at all from the electronics.
    No worry tho, because I think the thing to do here is supply my own stepper drive electronics and drive it from a cheap computer, of which I have many.
    This is a 2.5 axis machine- it appears that the Z is simply up or down and is pneumaticallly controlled. I'd like to make it a true 3 axis machine. From memory I'd say the working envelope is about 24"x18". Maybe not quite that big, but something like that. I could either use the engraving motor that is there or perhaps attach a small router.
    What do I want to do with it??? Well, mostly I just want to get my feet wet in the world of CNC. I think that if I could machine aluminum or plastic or wood, that would be great.
    I have a couple full size mills and a nice lathe, so I can fabricate whatever I need for the Z axis mod.
    Can anybody suggest my next move? I think I need to get specs on the steppers and then buy the proper gecko driver boards for it. And it so happens that I'm going to cabin fever next week...
    I'll post some pics and more details tomorrow.
    Aug 2014
    15
    Re: got Dahlgren engraver for retrofit- suggestions?
    Here is a blast from the past. Do you still have the machine? If it's something your willing to sell contact me, wayne at engravers dot net
    See my other post at http://www.cnczone.com/forums/engrav...-software.html to see I know a little about the Dahlgren engravers
  1. Wanted HI Drive logic board for Suregrave/Dahlgren engraver
    By splinters69 in forum Want To Buy...Need help!
    Last Post: 03-01-2014, 05:33 PM
  2. need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
    By lkasdorf in forum Uncategorised WoodWorking Machines
    Last Post: 05-11-2013, 02:50 PM
  3. Need Laser Engraver Suggestions
    By cbauman79 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-27-2013, 08:11 AM
  4. Looking for CNC Retrofit controller suggestions
    By pmitchel75 in forum Bridgeport / Hardinge Mills
    Last Post: 07-09-2010, 02:55 PM
  5. Suggestions for laser engraver around $4000
    By TacPyro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2009, 12:21 AM
