Originally Posted by
twocik
I need advice on how to pull this off.
I'm making threaded 15mm/0.590" rods. The rods will have a female and male thread ends. I've bought 15.875mm/0.625" solid stainless rods and plan to sand them down to 15mm. I'm running a 9 x 20 HF Lathe and own pre-ground internal & external 55° HSS threading tools.
Any advice on sanding or threading stainless steel please feel free....
For what it is worth, you need to remove .035", by "sanding"? I would turn them to within a thou or so, and then sand to final size if the final od is that critical. With the right cutter, they should cut pretty well, unless you have a weird alloy or something.
"we" need more information such as tolerances, type and harness of material, and any other info that you can think of.
Mike
Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
