585,970 active members*
4,457 visitors online*
    Jan 2009
    4
    alarm code 1024,1019
    I need help with a 2000 supermax rebel 1 w/Fanuc O-M control. I get a alarm code 1024 and 1015 when i try to do a tool change the machine is new to us and have no books. the changer moves the pot drops down but the arm does not move. the z is in home pos. and spindle is inline. Any help would be great. thanks
    Jun 2008
    1511
    Alarm codes in the 1000’s are external alarms. Description is the alarm was detected by the PMC ladder. If I am not mistaken these are written by the MTB. They will not be in the Fanuc manual. You will have to refer to the MTB manual or track down the alarm through the ladder or the diagnosis bits. If the MTB is still around then contact them and they will be able to tell what the alarm is from.
    Are you trying to change the tool to an empty tool or the current tool in the spindle? Does this happen on every tool? Some of my older Fanucs use to be really touchy with tool changes. You couldn’t change the tool if there was a value in the offset page “wear”.
    Stevo
    Jan 2009
    4
    alarm
    thanks Stevo I will look into this and follow up.
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Alarm code 123 VF-3
    By Nova in forum Haas Mills
    Last Post: 06-16-2010, 08:48 PM
  3. Alarm code
    By bob1427 in forum Uncategorised MetalWorking Machines
    Last Post: 01-13-2009, 12:39 PM
  4. Alarm code 203-6
    By meszarosg in forum Okuma
    Last Post: 10-11-2008, 09:17 PM
  5. fanuc alarm code need help
    By mike10 in forum Fanuc
    Last Post: 10-22-2006, 03:26 PM
