585,778 active members*
4,404 visitors online*
IndustryArena Forum > Mechanical Engineering > Linear and Rotary Motion > Mixing Preloaded&Standard linear trucks on same rail -pros and cons ?
    Nov 2008
    66
    Hi All,
    I've got an assortmentof 8 Hiwin HGH15 trucks with rails for 2 axes.
    4 of the slides are preloaded while the other 4 are standard and are easy to move.
    My questions is : is it bad to mix preloaded with standard trucks on same rail ? I'm thinking of distributing the 4 preloaded trucks for the 2 axes so I have a preloaded truck on each rail -any downsides ? Or is it better to have just only one type of truck on one rail?
    I can distribute them like this for each axis :
    1st rail -1preload+1standard
    2nd rail -1preload+1standard
    or
    1st rail -1preload+1preload
    2nd rail -1standard+1standard
    Which way is better ?
    Florin
    Mar 2006
    2712
    Florin, I'd go with the second arrangement. Two preloaded trucks on the guiding rail and two non-preloaded on the second rail. The non-guiding rail/truck assembly would carry some portion of the load as well as carry moment loads to counteract tilting/tipping tendencies.
    Just my $0.02
    Dick Z
    DZASTR
    Nov 2008
    66
    clear out a fact
    Just to clear out something :
    the trucks and rails are for the Z and Y(gantry) axes.
    I'm also considering using all the preloaded trucks for the Z, but not sure which axis need preloaded trucks the most, however I guess it's the Z where it's going the be most welcomed ?
    Florin
  1. pros and cons
    By stirling in forum Stepper Motors / Drives
    Last Post: 08-28-2007, 03:40 PM
  2. Plasma vs Torch- Pros & Cons - Looking to buy
    By txcowdog in forum Waterjet General Topics
    Last Post: 11-15-2006, 06:41 AM
  3. Slaved Motors Pros & Cons
    By destro in forum Waterjet General Topics
    Last Post: 07-18-2006, 03:28 AM
  4. Pros and Cons of Two Designs
    By PaulH in forum DIY CNC Router Table Machines
    Last Post: 10-22-2005, 03:22 PM
  5. What are the pros and cons of
    By cncadmin in forum CNC Machining Centers
    Last Post: 05-19-2003, 06:31 AM
