MSN & E-MAIL:[email protected]
Dahan Large-sized Laser Cutting Equipment(Optional Customized Models)
This item not only inherits the advantages of former laser machine but also has more technical innovations. It has the characteristics of short laser light, high utilizing rate in light, complete closed in laser light, strong security, advanced controlling software, stable operation, opening operation flat that can make the process breadth without limitation. This machine greatly satisfies the requirements of massive breadth and large amount processing industry by which improve the working efficiency and economic profit.
Applicable industry: costume, cloth, leather, furniture, package, advertisement, ornament, gift, architecture, paper, modeling and other related business.
Applicable material: cloth, acrylic, paper, leather, wood, organic glass, plastic, compound material, etc.
1. This machine can design and output the cutting sample with CAD software which improves the designing speed with multiple increases.
2. It has particular superiority for processing special types of material, for example, seamless underwear, and suit, tightens the edge, protection materials and wigwam. It has perfect precision, high speed and good quality.
3. Unique and advanced mechanical design, and laser light design, which can insure the equipment work normally, continuously and steadily. It is also easy to maintain.
Parameters
Item: Large-size Laser Cutting Machine
Machine Size:3030*2060*1120mm
Max Engraving Size:1300*2400mm
Net Weight:360kg
Laser Power:80w/100w
Resolution :0.025mm/step
Location Precision: ±0.01/300mm
Gross Power: 500W
Cutting Speed: ≤200mm/s
Engraving Speed: 0-1000mm/s
Working Environment: 5-35℃
Power Source: AC 220v/50hz±5%
Cooling Way: Industrial Circulating and Cooling System
