Hello, Im design a CNC router for a college project, but im getting a bit stuck with the calculations.
I've done an experiment to try and calculate the force required to cut a groove though a sheet of MDF at a depth of 6mm with a woodworking router, this showed that with a mass of 8kg attached to the router with a piece of string would pull the router at said depth at a rate of 0.02m/s.
So, the question is, how can I use this information to calculate the power required to move that router in watts, instead of kg. And then use that to calculate the stepp
I'd really appreciate any information you can give me on this, I'm really struggling to get my head around it.
