Grrr. damned lasers :-)
I had this same problem over the last few days and it's taken about 3 days to get it all sorted out.
I'm using Linkmotion and Corel X3. What are your specs?
Dhiren and the team at Solustan were very helpful with a few suggestions on what to try and I also ended up rewiring the laser table again with twisted pair shielded wires and earthed the shield to the frame to see if that made any difference. It only took about 1/2 hour to do. It still no effect on the double image or ghosting.
Do this -
Draw a rectangle then unfill it and set hairline then engrave the rectangle in Vector mode. return to to 0,0.
Then fill the rectangle and set the laser to raster engrave and set the dots per inch to a low setting of about 20 dpi.
This will separate the raster lines so you can see what is happening.
If the lines are staggered alternately down the side of the rectangle then you probably have a problem with the mechanics.
My system had the staggered lines but I couldn't detect any play in the drive system at all the first day so I went looking for other problems. I finally went back and tested the toothed belt drive cogs and REALLY gave them a good twist and to my surprise one of them moved but barely perceptibly. I tightened up the pulley using new screws that were a bit longer and tried it again. I then had a smaller ghost effect but it was only on some of the characters I was engraving. I pushed the lens trolley along by hand and noticed there was a bit if grabbing that I found was rust on the bottom rollers so I cleaned the V guides with steel wool and oil and behold the problem went away.
I had 2 problems,
1 was the loose pulley
2 was too tight a rail guide system
When engraving at 3 ipm the problem wasn't there but at 6 ipm it was. Seems as though the tight rail system and the extra inertia was enough to cause the problem.
If you engrave at 200 - 300 dpi, the lines are so close together you can't see the alternating starting and stopping from each line which looks like the double image you and I have encountered.
If your mirrors were out of alignment then your image would fade to one side or the other but you image is the same across the whole picture which looks like it is a mechanical fault.
I hope I was of some help and don't discard anything without trying it again (like I did).
Don't despair too much as there are some very helpful people here who will always get back to you with some sort of helpful advice.
I am not completely useless.......I can always serve as a BAD example.
