585,978 active members*
4,345 visitors online*
Results 1 to 9 of 9
    May 2006
    41
    RFQ, Small job, mounting brackets
    Hi guys;
    Sadly, this is only a small job, but maybe someone has a couple of hours open that they'd like to fill.
    This is a mounting bracket for circuit cards, .25 x .25 x 1.65, with 4 threaded 4-40 holes. Tolerances are nominal.
    Material is not critical, aluminum or steel, any alloy.
    Break all edges and flush chips so that part does not any shed any latent tiny chips onto circuit boards.
    Typical clean mill finish without any dramatic tool marks is fine.
    I need 72 pieces, in 2 weeks or less.
    Drawing is attached.
    You can contact me directly at sswitaj (at) aol (dot) com
    - Steve
    Attached Files Attached Files
    Mar 2005
    140
    Relatively straight forward part, the only real problem I see is that if the end holes break through the traverse holes it would compromise the threads slightly.
    Would standard 0.25" stock be fine? This would save a fair bit of machining.
    Jan 2009
    23
    hi,
    please send a print to [email protected]
    Jul 2005
    80
    If still open
    Sent PM. Mike.
    Mar 2006
    32
    Pleas send me a print along with an exact due date. [email protected]
    thanks.
    Sep 2006
    74
    quote
    Bidding closed ?
    Dec 2006
    116
    If the job is still open, I would like to quote it. Is material cost to be in the quote? Thanks [email protected]
    Mar 2009
    7
    Still open? I would like to bid,
    Matthew Yonekura (408)661-3732
    Email: [email protected] Research Machine Development Inc.
    Apr 2007
    22
    sent you a quote to your aol e-mail,thanks Joe @ tuson enterprises
    Tuson enterprises
  1. servo motor brackets
    By lyncomputer in forum Want To Buy...Need help!
    Last Post: 02-19-2009, 03:34 AM
  2. brackets
    By Runner4404spd in forum Employment Opportunity
    Last Post: 07-27-2006, 11:41 AM
  3. Angled Brackets
    By JohnG in forum DIY CNC Router Table Machines
    Last Post: 05-19-2006, 10:10 PM
  4. RFW steel brackets
    By AustinT in forum Employment Opportunity
    Last Post: 05-11-2006, 04:47 AM
  5. Bridgeport X Y brackets and pullys
    By Fabric8r in forum Bridgeport / Hardinge Mills
    Last Post: 12-31-2004, 05:00 PM
