Where Used Report
Originally Posted by
sk96_me45
Hello Everybody,
1). I opened a part in nx-4 and want to know that in which assembly this part has been used?
2). Also I want to know the path of the part, in which folder I had saved it?
In NX4 there is a Where Used report you can use. Select Assemblies - Reports - Where Used Report. Enter the name of the component - it defaults to the work part. You can use the Search Directories (set on the load options dialog), Search the part Directory or enter a directory path.
Now sit back and wait - it may take a while. When it is done the information displays with the other assemblies where the component is used and the directory path. I would suggest reading the help docs on this topic.
John Joyce -NC Programming Supervisor
Barnes Aerospace, Windsor CT
