585,991 active members*
5,740 visitors online*
Results 1 to 12 of 12
    Jul 2008
    17
    Talking Another HB Jet engine
    And so to date I have completed the shaft, housing, and lately the diffuser - quite impressed wid myself...... see pics....... I invite all enthusiasts to chat!!!
    Attached Thumbnails Attached Thumbnails diffuser1.jpg   Shaft+C+T.jpg   T+S+C +H Ass2.jpg
    Oct 2006
    120
    looking good so far. what will it be when you have finished........... and don't say a turbine:-)
    Jul 2008
    17
    Hi there!!!
    Yip I aspire it to be a gas turbine...... okay so if it dont run then maybe it could pass for a fancy doorstop (NooooT!). Fascinated with gas turbines and their ability to power large aircraft I challenged myself into building one. Yes there is the conventional method of converting a turbocharger (I started with this) into one but it just didnt follow the 'axial' profile of a jet engine....
    ....So enter the realm of hours on weekend and negotiations with the MR's....hehe...
    Aug 2003
    327
    Nice work. What are you basing it on. Looks like a KJ-66, but i could be wrong
    Jul 2008
    17
    Quote Originally Posted by mikie View Post
    Hi Mikie,
    Thanks, Yes the idea is based on a kj66 but a bit smaller in comparison - the turbine and engine size depended on the compressor wheel I had in my workshop.....
    Project a bit slow now - as I am building a home foundry setup to cast components - will try the turbine wheel aswell.....
    Aug 2003
    327
    Good luck with that. Thats grabbing the bull by the horns!
    Jul 2008
    17
    Are you working on a similar project?
    Aug 2003
    327
    Yes, Build Thread KJ-66 in this section
    Jul 2008
    17
    Quote Originally Posted by Praised1 View Post
    www.theworkshopsman.yolasite.com
    Aug 2003
    327
    Hi Praised,
    Can you advise me how you went about the diffuser.
    I assume some it was manually completed as 5 axis machines are rare in homes.
    I figure the following sequence:
    1. machine and face both sides and outer diameter.
    2. machine 4 bolt holes
    3. locate in mill and complete stator machining
    4. machine in mill or lathe the outer stators.
    Question for pt4. - how did you machine the airfoil shape into the stator.
    Question on the outer shaft, did you just use 2000 series aluminium or did you go for a 6000 series free machining ali instead.
    PS; i see on your website, you mention you have CAD drawings for the KJ-66. Any chance of obtaining a copy so I don't have to draw it all from scratch?
    thanks for any help in advance
    Michael
    Jul 2008
    17
    Hi Praised,
    Michael
    Hi!
    Tnx 4r your feedback!
    Always glad to help! do u have an email ad that i can send drawingss to? will send info on the diffuser machining aswell
    Aug 2003
    327
    Just sent you a private message
  1. Search drawing from free piston engine ->stelzer engine
    By Enginetuner in forum I.C. Engines
    Last Post: 12-20-2022, 11:13 PM
  2. Hot Air Engine
    By OG LIM in forum Hobby Discussion
    Last Post: 05-04-2008, 07:06 AM
  3. engine for UHU?
    By Jakubik in forum Open Source Controller Boards
    Last Post: 10-10-2007, 03:43 PM
  4. two stroke engine
    By PoWaKiD42 in forum I.C. Engines
    Last Post: 10-03-2007, 06:59 AM
