585,902 active members*
4,261 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco Fet Servo amps
    Oct 2008
    78
    I'm replacing the controller on my SM-1. I'm down to the amps I have figured our the wires that were used on J8, J9 and J10 connectors does anyone have the info on the two unused pins of these connectors and the info on J16.
    Any info on the LEDs on the front of the Axis cards?
    Amp # 002-1690-001
    Donnie
    Oct 2008
    78
    Any one have any ideal how Hurco disabled the amps other than kill the dc power and waiting on the Cap to bleed down? I first thought that J16 with two wires come off the up left side of the backplane was it but the white wire is ground potional and the blue is 10 volts short it to the white wire and it kills the amps for about 2 seconds and then the amp re-enable.
    Donnie
  1. Cleaning Fanuc Power supplies, Servo amps?
    By FanucIssues in forum Fanuc
    Last Post: 06-07-2007, 08:43 PM
  2. Wanted A/C servo amps & motors
    By Bap in forum Servo Motors / Drives
    Last Post: 05-13-2007, 06:23 PM
  3. older Brush Servo amps
    By miljnor in forum Haas Mills
    Last Post: 02-19-2006, 04:06 AM
  4. Howto find input amps, from output amps on transformer?
    By sendkeys in forum CNC Machine Related Electronics
    Last Post: 07-15-2004, 01:13 AM
  5. DC servo amps
    By converterk in forum CamSoft Products
    Last Post: 12-22-2003, 06:09 AM
