585,996 active members*
4,510 visitors online*
    Nov 2007
    14
    km3 move very slow
    hi, All
    my mill km3 have some problem on manual mod all axes is moving very slowly and when i send NC data from my PC recive correctly but work slowly as manual mod untill feed rate is 1000 and also feed rate nob is not geting slow or fast it is not working please help me
    Oct 2008
    42
    What control do you have? B, BX or Ultimax?
    Buddy
    www.amtsinc.com
    Nov 2007
    14
    ultimax control
    first thanks a lot,
    i have km3 with ultimax. problem is that my all axes are running very slow on both mod (manual,Auto) i checked that upper connector of "fault logic board" was loose i pushed it machine start again now machine is not power up and dual axes board have two green LED "DS1 and DS2" after some time DS1 LED get off but when i pulled out the upper connector of F.L.Brd so machine power up normaly all axes move but very slow.
    hope you will help.
    Apr 2007
    5
    i will help u
    Quote Originally Posted by junaid.wahid View Post
    hi, All
    if u from pakistan u call me i will help u 03009211929
  1. Why so slow?
    By happytriger2000 in forum Mach Mill
    Last Post: 12-06-2006, 12:36 PM
  2. slow tm-1
    By pit202 in forum Haas Mills
    Last Post: 04-18-2006, 08:14 AM
  3. The X-Axles... to move or not to move!
    By Wild4aces in forum Mechanical Calculations/Engineering Design
    Last Post: 03-18-2005, 08:26 PM
  4. Slow Jog
    By Don C in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-02-2004, 06:34 PM
