585,906 active members*
3,739 visitors online*
Thread: Chuck & Jaws
    Dec 2008
    39
    Question Chuck & Jaws
    My lathe chuck ( jaws ) have a eccentricity of 0,004". I would like to correct this problem. What is the better way to correct and how can I do that? I would like to grind the jaws.
    Best regards
    Jean-Denis
    Mar 2008
    3655
    Hello Jean. Welcome to the Zone!
    Maybe this will be helpful:
    http://www.varmintal.com/alath.htm#Toolpost_Grinder
    http://www.varmintal.com/alath.htm#Truing
    CR.
    Feb 2007
    1084
    or a boring bar works for me. It's a common problem with a scroll chuck. The scroll on cheap chucks isn't very precision, machine the jaws for one diameter and they will run perfectly true, open up to a larger diameter and they will probaby run out again.
    5c collets are much more precision and give a much better grip on the material, yet have a smaller thru bore(in most cases) and require changing between hex stock, round stock and diffrent diameters.
    Welcome to the wonderful world of precision machining!
    Jan 2009
    We use softjaws on our scroll chucks. Indicate the chuck in round, chuck on something to put tension on the masters, and start tooling out the jaws. We run lots of molds, and if the jaws are tooled right they will run true everytime. We often tool out several diff. diameters on one set of jaws so you dont have to change jaws all the time. A good scroll chuck always helps.
  1. Boring soft chuck jaws for ID holding?
    By SRT Mike in forum MetalWork Discussion
    Last Post: 03-15-2013, 07:19 PM
  2. Newbie. Need to make soft chuck jaws for Mori lathe
    By bob1112 in forum Uncategorised MetalWorking Machines
    Last Post: 03-14-2008, 02:07 AM
  3. milling chuck jaws
    By theatrewizard in forum Haas Mills
    Last Post: 02-28-2008, 05:09 PM
  4. CNC Lathe chuck with adjustable Jaws ?
    By Larken in forum Uncategorised MetalWorking Machines
    Last Post: 02-03-2008, 05:47 PM
  5. truing lathe chuck jaws
    By wrenchcruncher in forum Uncategorised MetalWorking Machines
    Last Post: 01-17-2007, 07:03 PM
