585,775 active members*
4,329 visitors online*
IndustryArena Forum > Community Club House > Precise jig grinder
    Oct 2008
    12
    Precise jig grinder
    I have a precise jig grinder model jil. it seems the bearings are going out of it. I do not know what thread to post in for help or advice on where to get it rebuilt any info is appreciated.
    Chris
    Nov 2008
    RE: Model JIL Replacement Bearings.....
    CK...
    If you get the machine pulled down, you should be able to get the numbers off the bearings and go to a bearing company ( like, say, Motion Industries ) and they can match the bearings up for you. It'll be a whole lot cheaper than trying to go back through the machine manufacturer (if they are still in business). I have to do this with a lot of the machinery at our shop. Hope this helps you out!!!
    Dec 2005
    3319
    NOT all of the special features needed to insure PROPER bearing interchanges are found on the bearings.
    Examples
    Preload (very critical due to speed vs stiffness issues)
    Radial runout (sometimes special vis use of ultra precision balls)
    Select fits of OD or ID.
    Noise qualification
    SPecial grease or fill.
    Axial runout specs
    yes you can get close via the "numbers on the bearing" but not always
    Do plan on having the ID taper reground. Failure to do so will/can result in a very unpleasant experience with tool runout/chatter that "magically appeared".
    Revuilding the spindle is MORE than slapping in new bearings
    Mar 2006
    2712
    Are you referring to a Precise brand spindle? If so, you may want to contact Fischer Precise USA Inc. Phone number is 262/632-6173.
    I have no connection with them, just a long time customer.
    Dick Z
    DZASTR
  1. precise movements in mach....how do I...
    By cephjedi in forum Mach Software (ArtSoft software)
    Last Post: 04-05-2007, 12:52 AM
  2. Precise Mini Mill?
    By ZipSnipe in forum Benchtop Machines
    Last Post: 03-18-2006, 12:47 AM
  3. Precise Radius Grinding?
    By Otokoyama in forum MetalWork Discussion
    Last Post: 03-06-2006, 12:45 AM
  4. Are ballscrews necessary for PRECISE work on a cnc lathe?
    By daytrader in forum Uncategorised MetalWorking Machines
    Last Post: 01-10-2005, 07:34 PM
