i had deleted the ram of my fanuc controller series OT and now my keyboard is not working correctly. It's strange because when i am in the offset mode the keyboard is enable to introduce data this happen also in program mode but in this case the keyboard works like the compact version where the letters and the numbers are in the same key. Now, when i want to do the same action to set parameters, the keyboard doesn't work. A thecnician told me that i can't introduce parameter because the system initialize in EDIT mode and should be in MDI mode, but we can change it. Another solution was change the keyboard to the compact version (the daewo 8HC has a extended keyboard that includes letters) but we are still looking for it. If you have any idea about it, i'll be pleasured.
Regards
