I am trying to do a counter bore on master X2.
Any assistant?
Any assistant?
OK, what is the trouble you are having ?
2d contour with ramp , circle mill ?
If you want to interpolate a counter bore superman is right, you can use 2d contour with ramp or circle mill.
2d contour with ramp: You draw the dia. you want and when you chain it use the ramp option. You can at that time pick you distance per rev or angle.
circle mill: You can just chose a point for the location and than you tell it the dia. and the ramp you want to use.
If you're just trying to make a counter bore and you are refering to the tool entry, you could use a pocket toolpath and check the "Entry-Helix" box on the Roughing/Finishing tab, then manipulate the setting to achieve the entry helix you want
I like that... post a really vague question and then dont come back to get an answer.
Mike Mattera
Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
http://www.tipsforcadcam.com
