585,589 active members*
3,706 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai HIT 15s/error 9161
Results 1 to 7 of 7
    Jan 2009
    Hello, i am trying to troubleshoot a 9161 (machine not ready) alarm on startup. I've followed the fault tree and even replaced a thermal 24vdc contactor in the circuit, but still no help.
    If anyone has ever had this alarm in the past, what steps did you take to correct? Also, if any available documentation, that would be helpful too.
    Andy
    Jul 2006
    20
    Andy,
    Probably not much help but my book says:
    Cause: No "machine ready signal" or "hydraulic on" signal.
    Action: Check breaker QFB2, QFB3 and thermal relay QFB6.
    Check the "machine ready signal" and connections.
    Check the magnetic contact and thermal relay of hydraulic pump motor.
    Afraid that is about all the help I can offer. If you have found a solution, please post for the rest of us.
    Ken
    Aug 2008
    93
    Re: Hyundai HIT 15s/error 9161
    I just got this error too. It is not listed in my book. What manual are you looking in that lists it and shows a trouble tree? I need to get that book.
    Aug 2008
    93
    Fixed, at least for now. Pressed a reset button on the keyboard circuit board under the monitor. Now we see it it happens again.
    Jul 2006
    20
    Quote Originally Posted by BNR_RANDY View Post
    My original post is about all the help I can offer. Its from the instruction manual that came with the lathe.
    Ken
    Aug 2008
    93
    which book is that? Title, publication number? Is it a Hyundai or a Siemens book? Mine books do not have this error in them.
    Jul 2006
    20
    Again, it is the instruction manual that came with the lathe. The manual has 9 books and one of the books lists the alarm codes. The alarm code book has the following info:
    Hyundai 1996 All Rights Reserved
    Subject to change without prior notice
    Page No. : 2-39
    Rev No. : 2(9612)
    Book No. : Z99HP110100
    If you need the latest revision you can call the Operation Center of
    Hyundai Precision or Regional Office
    Please send request to
    Hyundai Precision & Ind. Co., Ltd
    Operations Center
    1162 Tower Lane
    Bensenville, IL 60106
    Tel 7089-596-4587
    Fax 708-595-0697
    This information is from 1996 so its validity is questionable.
    Ken
  1. hyundai hit 8
    By drill in forum MetalWork Discussion
    Last Post: 09-10-2012, 01:17 AM
  2. hyundai hi t 8
    By Cartel, LLC in forum Hyundai Kia
    Last Post: 02-08-2012, 12:07 AM
  3. hyundai 18s
    By protoman1 in forum Hyundai Kia
    Last Post: 02-07-2012, 11:48 PM
  4. Hyundai HIT 15S
    By lesarcs in forum Hyundai Kia
    Last Post: 12-28-2011, 10:44 PM
  5. Hyundai VMC
    By kevinkoons in forum Hyundai Kia
    Last Post: 03-30-2009, 06:27 PM
